Help sending TCP/UDP commands to LED light controller
I’m looking for some help to control STICK-DE3 LED controller ([https://www.nicolaudie.com/stick-de3.htm]). This device can be controlled via TCP/UDP commands. I have verified this by sending various network packets to the device from my PC using using a software utility called “packetSender” . Can anyone recommend how to get this working with via HA. I’m very new to the HA and trying to come up the learning curve. Any help will be greatly appreciated.
Hi, I’d like to do the same as you : I have a H801 RGB controller, and need to send packets to control it.
Did you find a solution ?
I have 12 Nicolaudie Stick KE2 throughout my home. I can use PacketSender to control them all. I “just” need to send UDP packets to these controllers (Stick’s). Anybody?
