This works to turn on/off, but the problem is that HA is not aware on the device’s real on/off state because it is also possible to turn on/off the physical device via a physical button.
Therefore I did set up the following shell_script command, which is returning either a value of 1 or 0, depending on the device’s on/off state:
Now my question is: How would I set the state on the custom switch entity depending on what value is being returned from the CURL shell script? I thought of a template helper, but I am not sure on how to code this. Can someone help me out with this?
Thanks in advance!
yeah, you could do a template sensor. you’d have to determine when you want to update that sensor. some poll frequency? here’s a general idea to get you going:
template:
- trigger:
- platform: time_pattern
# This will update every minute
minutes: /1
### put your shell_command here
- action: shell_command.getstate
response_variable: shell_command_response
- name: "name of sensor"
state: >
{{ jinja to parse shell_command_response }}
info about shell_command response_variable and examples here:
I’m not sure if I understand this correctly.
So the sensor in your example will automatically update the already existing switch entity state?
If so, the code would look like this?
template:
- trigger:
minutes: /1
- action: shell_command.gude_epc_8211_port06_getstate
- name: "test"
state: >
{{ switch.gude_epc_8211_port06 = shell_command_response }}
Not sure about this but would HA automatically interpret a “1” as “on” and a “0” as “off”?
hmm… given your response, am i correct to guess that you’re not familiar with jinja and templating in home assistant? i don’t want to presume too much or also certainly don’t mean to offend if you’re quite jinja capable.
no, that won’t work. that’s not how jinja or sensor templates work. the state should get the value you want. the response_variable receives the value in a dictionary. look at the link i gave above. it explains it and also gives examples. i don’t know your script and how it returns, but to take a wild guess
template:
- trigger:
minutes: /1
- name: "test"
state: >
{{ shell_command_response['returncode'] == 1 }}
