I already added the doorbird config, but I would like to add it as a camera so I can stream it on my Smart Display by “Hey Google, show me the camera” I already do this with a different camera with rtsp. Any help would be appreciated, thanks. I already know I can do http://192.168.0.89/bha-api/video.cgi?http-user=(username)&http-password=(password), but that is NOT rtsp.
The rtsp address for Doorbird camera’s is this:
rtsp://username:password@yourcamera_ip/mpeg/media.amp
You can test it out in VLC it should work there.
The doorbird component is even easy to use, I just figured it out, it’s actually very easy.
Setup your doorbird:
doorbird:
devices:
- host: your_doorbird_ip
username: your_username
password: your_password
token: your_token
events: # Whatever events you have created to use in home assistant
- doorbell_1
- motion_detected_gate
camera:
- platform: doorbird
And then you will have some new entities in home assistant:
camera.<name_of_your_doorbird>_last_motion
camera.<name_of_your_doorbird>_last_ring
camera.<name_of_your_doorbird>_live
Thanks for the RTSP. The only reason I want it is so I can ask Google Assistant for it on a Nest Hub. Thanks!
Edit: I added the camera part but it doesn’t show in entities. I will probably use generic camera.
