ben0551
(Benjamin)
July 23, 2021, 1:17am
1
I want to setup a custom device tracker for when family members visit. Sometimes they visit to feed pets when I am away etc etc. In this instance, I am not going to install the companion app on their phones as that’s overkill.
I have a Deco x20 router which doesn’t give API access. I have been able to setup an automation to send a notification to my phone when a device joins or leaves the network and I have setup the “last_message” sensor via the companion app to feed the join/leave notification to Home Assistant.
On HA Logbook
[Ben LG Last Notification] changed to G8S-ThinQ has disconnected from the WKF’s network.
Wish this, how can I create a tracker which I can then allocate to a user in Home Assistant?
Many thanks,
ben0551
(Benjamin)
July 23, 2021, 1:19am
2
They have all connected to my WIFI in the past, so this method should be the most exact until I get a coded door lock.
finity
July 23, 2021, 5:33am
3
you can manually create a device tracker using the known_devices.yaml file.
then once you create the device tracker you can use the device_tracker.see service to update the status of the device tracker to the home location.
But I’m not sure how you could use the data above to trigger an automation to update the device tracker.
Here is the automation I use to set the location of my vehicle for location of where I parked:
- alias: Set Tacoma Location
- platform: state
entity_id: sensor.my_mobile_app_bluetooth_connection
- platform: state
entity_id: person.me
to: 'home'
choose:
- conditions:
- "{{ trigger.entity_id == 'sensor.my_mobile_app_bluetooth_connection' }}"
- "{{ 'the mac of my phone' in trigger.from_state.attributes.connected_paired_devices }}"
- "{{ 'the mac of my phone' not in trigger.to_state.attributes.connected_paired_devices }}"
sequence:
- service: device_tracker.see
dev_id: toyota_tacoma
location_name: "{{ states('device_tracker.my_mobile_app') }}"
gps:
- "{{ state_attr('device_tracker.my_mobile_app', 'latitude') }}"
- "{{ state_attr('device_tracker.my_mobile_app', 'longitude') }}"
- delay:
seconds: 10
- service: variable.set_variable
variable: tacoma_location_saved
value: "{{ states.device_tracker.toyota_tacoma.state }}"
attributes:
latitude: "{{ states.device_tracker.toyota_tacoma.attributes.latitude }}"
longitude: "{{ states.device_tracker.toyota_tacoma.attributes.longitude }}"
- conditions:
- "{{trigger.entity_id == 'person.me'}}"
sequence:
location_name: home
gps: [my home location in coordinates]
- delay:
seconds: 10
attributes:
ben0551
(Benjamin)
July 23, 2021, 5:53am
4
alias: g8s Home
description: ‘’
platform: state
entity_id: sensor.ben_lg_last_notification
to: G8S-ThinQ has joined the WKF’s network.
condition: []
device_id: 295d8675ec780c17b0049933f9bf2f0d
domain: mobile_app
type: notify
title: ‘’
message: TEST Join
mode: single
I’d use that to update the see. Will try the known devices
finity
July 23, 2021, 5:54am
5
Sorry I just updated my post above with an example I used.
ben0551
(Benjamin)
July 23, 2021, 6:17am
6
What does your known_devices yaml look like for this example?
finity
July 23, 2021, 6:21am
7
toyota_tacoma:
icon:
mac: 66:AA:33:55:FF:EE <fake mac of my phone bluetooth>
picture: /local/tacoma.jpg
track: true
I don’t think it matters what the mac is that you use as long as it’s not the same as any other on your network.
ben0551
(Benjamin)
July 23, 2021, 6:23am
8
thanks! looks nice and minimal!
Hellis81
(Hellis81)
July 23, 2021, 6:44am
9
You could also reserve the IPs on the router and use ping
ben0551
(Benjamin)
July 28, 2021, 9:18pm
10
Thank you all above. My person automation is working great! How nice it would be for Decos to not be locked behind an app though. Sigh.
Hi @ben0551
I’m in exactly the same situation as you - Deco X20, and wanting to update an individual’s presence based on them joining WiFi.
Could you explain what you did to enable this, in terms someone who has been using HomeAssistant for about a week ( ), might understand, please?
Thanks!
ben0551
(Benjamin)
October 24, 2021, 10:42pm
12
This was flaky and I did not continue with it
Set X20 to send connection notifications.
Enable last notification sensor on the HA app on mobile.
Add Automation to set the home/away status based on he last notification
It worked 70-80% of the time.
Using a Ping sensor and a reserved address would be better but would still cause false positives when moving outside/poor reception areas of house.
