Used cloud-cutter on two Cleverio bulbs
1st: E27 running CBL2 board, went fine color changing is good.
2nd: E14 with CBLC5 board. In HA there are 4 color buttons, from warm to cold. The 2 buttons in the middle work perfect, the warmest and coldest buttins work porly. Only reacts when setting the brightness in off mode. Cant dim, turns off when dimming.
Same config on both, exept board selection.
Any ideas?
Config:
esphome:
on_boot:
then:
- light.turn_on:
brightness: 40%
bk72xx:
board: cblc5
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "CVPrmS47mwiWBfU2l5SNtkdScxogI4VH0AVwFSS6yQU="
ota:
password: "f1c1c941705cc7d77950fdc7512130d9"
wifi:
ssid: !
password: !
ap:
ssid: "cleverio1 Fallback Hotspot"
password: "qxnl2hY3DMTZ"
captive_portal:
button:
- platform: restart
debug:
update_interval: 30s
text_sensor:
- platform: debug
reset_reason:
- platform: libretiny
version:
output:
- platform: libretiny_pwm
pin: P26
pin: P24
light:
- platform: cwww
cold_white_color_temperature: 6500 K
warm_white_color_temperature: 2700 K
cold_white: output_cold
warm_white: output_warm
