Help Setting Up Lovelace
I have hassio up and running. Everytime i try to customize lovelace i get lost.Not sure where to start or there is template i can import to customize
Try to play with the start template you can add.
Follow how you can install Lovelace, and there’s a section with a start template: https://www.home-assistant.io/lovelace/dashboards-and-views/
Or else, search on google for topics where people show their configuration.
Most of them are on github, you can make up a few ideas…
example: https://www.reddit.com/r/homeassistant/comments/9bgfo6/my_home_assistant_setup_share_yours/
