- Home Assistant 2024.2.1 installed via Docker Container on Ubuntu 23.10
GOAL: Matrix as a temporary frontend for HA when I can’t access the full system due to performance limitations, for both feed and common ‘actions’/scripts.
Hi since the documentation is great and the issue simple I feel silly asking,
but although I swear I got it to respond once, I can’t seem to get the notifier to listen at all. When I hit run actions on an automation it can send via matrix_notify fine
I am on matrix.org and my botuser is only used by my HomeAssistant configuration.
configuration.yaml
notify:
- name: matrix_notify
platform: matrix
default_room: "#MYROOM:instance.tld"
matrix:
homeserver: https://matrix.org
username: "@botuser:instance.tld"
password: "my secure password"
rooms:
- "#MYROOM:instance.tld"
commands:
- word: lightsoff
rooms:
Here’s my automation that the actions work but the listener does not:
alias: 08matrix_command.trigger_lightsoff
description: 08 - ondemand commands
- platform: event
event_type: matrix_command
event_data:
command: lightsoff
condition: []
- service: notify.matrix_notify
message: You have triggered the 'lightsoff' command 🚫💡.
- service: light.turn_off
metadata: {}
data: {}
area_id:
- living_room
- bedroom
- spare
- kitchen
mode: single
To clarify by not working - the trace history is empty other than manual trigger.
Bigger picture: What I am trying to achieve is a twofold: A feed that shows me some basic information in list view without having to connect to my HA instance directly, like when people come and go and whether the lights actually turn off and doors shut etc. and Secondly a way of interacting with HA with old hardware - I have no smart switches so I use old iphones and ipads and some aren’t compatible with the HA app and some are very slow, so sending a matrix message is a faster way to interact.
