So, I tried both of the links that you had provide(thanks!). I typed the following command to see where the USB device location:
$ ls -l /dev/serial/by-id/
total 0
lrwxrwxrwx 1 root root 13 Nov 13 22:13 usb-Silicon_Labs_HubZ_Smart_Home_Controller_612019D6-if00-port0 -> ../../ttyUSB0
lrwxrwxrwx 1 root root 13 Nov 13 22:13 usb-Silicon_Labs_HubZ_Smart_Home_Controller_612019D6-if01-port0 -> ../../ttyUSB1
So, this tells me that it’s using both USB0 (presumably z wave) and USB1 (zigbee?). I’ve tried both ttyUSB0 and ttyUSB1 in the configuration file with similar results.
I also tried listing the USB devices with the following results.
$ lsusb
Bus 001 Device 004: ID 10c4:8a2a Cygnal Integrated Products, Inc.
Bus 001 Device 005: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I also tried listing the USB based on the official troubleshooting techniques.
$ ls -ltr /dev/tty*|tail -n 1
crw--w---- 1 root tty 4, 1 Nov 13 22:13 /dev/tty1
I’ve tried modifying everything in the configuration.yml file and still receiving the same error even when using the serial path.
2018-11-14 17:31:21 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry OnHub for upnp
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/config_entries.py", line 241, in async_setup
result = await component.async_setup_entry(hass, self)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/upnp/__init__.py", line 128, in async_setup_entry
await device.async_add_port_mappings(ports, local_ip=local_ip)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/upnp/device.py", line 69, in async_add_port_mappings
internal_port)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/upnp/device.py", line 90, in _async_add_port_mapping
lease_duration=None)
File "/srv/homeassistant/lib/python3.5/site-packages/async_upnp_client/igd.py", line 195, in async_add_port_mapping
await action.async_call(
AttributeError: 'NoneType' object has no attribute 'async_call'
2018-11-14 17:31:35 WARNING (Dummy-25) [openzwave] Z-Wave Notification DriverFailed : {'nodeId': 255, 'notificationType': 'DriverFailed', 'homeId': 0}
2018-11-14 17:34:48 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.my_ecobee is taking over 10 seconds
2018-11-14 17:34:54 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:15
2018-11-14 17:35:10 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:15
2018-11-14 17:35:26 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:15
2018-11-14 17:35:29 WARNING (Thread-22) [pyecobee] Error connecting to Ecobee. Possible connectivity outage.
2018-11-14 17:36:36 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave not ready after 300 seconds, continuing anyway
2018-11-14 17:36:53 ERROR (Thread-19) [homeassistant.core] Error doing job: Future exception was never retrieved
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/zwave/__init__.py", line 697, in _finalize_start
network.set_poll_interval(polling_interval, False)
File "/srv/homeassistant/lib/python3.5/site-packages/openzwave/network.py", line 894, in set_poll_interval
self.manager.setPollInterval(milliseconds, bIntervalBetweenPolls)
File "/srv/homeassistant/lib/python3.5/site-packages/openzwave/network.py", line 564, in manager
raise ZWaveException(u"Manager not initialised")
openzwave.object.ZWaveException: 'Zwave Generic Exception : Manager not initialised'
2018-11-14 17:38:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.my_ecobee is taking over 10 seconds
2018-11-14 17:38:48 WARNING (Thread-21) [pyecobee] Error connecting to Ecobee. Possible connectivity outage.
2018-11-14 17:41:58 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.my_ecobee_humidity fails
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 221, in async_update_ha_state
await self.async_device_update()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 349, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
At last attempt, the configuration file reads:
zwave:
usb_path: /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_612019D6-if00-port0
Any additional help would be greatly appreciated as I’m pretty much at a stopping point now. ![:frowning: :frowning:](https://community.home-assistant.io/images/emoji/twitter/frowning.png?v=9)
