So I’d like to see the UPS status and Battery status of the UPS in Home Assistant and came across the NUT component.
Mind you that I already installed the NUT server in the past so it’s already running on the same pi!
pi@hassbian:~ $ sudo /etc/init.d/nut-client status
● nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller
Loaded: loaded (/lib/systemd/system/nut-monitor.service; enabled)
Active: active (running) since Fri 2017-03-17 16:06:39 CET; 2 weeks 6 days ago
Main PID: 813 (upsmon)
CGroup: /system.slice/nut-monitor.service
├─812 /lib/nut/upsmon
└─813 /lib/nut/upsmon
Mind you that I already installed NUT on my pi like this:
On the raspberry you need to install NUT
sudo apt-get install nut
edit the monitoring config
sudo nano /etc/nut/upsmon.conf
Scroll down to the part MONITOR
# MONITOR [email protected] 1 upsmon secretpass slave
# MONITOR myups@localhost 1 upsmon pass master (or slave)
and add below:
MONITOR [email protected] 1 monuser secret slave
Change the IP to the IP of your NAS. All the other info suitable for every Synology NAS
Save the file and quit nano
Edit nut configuration
sudo nano /etc/nut/nut.conf
Change MODE=none into
Code: Select all
MODE=netclient
Start monitoring the remote UPS server
sudo /etc/init.d/nut-client start
When I then run this command:
it returns that it’s running fine:
● nut-monitor.service - Network UPS Tools - power device monitor and shutdown co ntroller
Active: active (running) since Fri 2017-03-17 16:06:39 CET; 1 months 8 days a go
Might the automatic NUT setting up of HASS somehow interfere with my already installed NUT service?
Is there a way to just “read” that status and show it in HASS somehow?
The HASS component doesn’t modify anything on your installed service. It looks like you aren’t running the NUT server component on you PI, just the client. You need the server part to allow HASS to fetch the data.
Also @mezz64: Ok I understand what I did wrong now. I thougt pi3 runs the server but of course that’s not true!
My Synology NAS runs the server and indeed pi3 NUT is just a client.
I now used the Synology NAS ip address as host in the HASS NUT component and…tada works right away! :).
Luckily it was not needed to setup a new NUT server :).
Thanks both of you for helping me think in the right direction!
So i have this setup and working but some of the variables dont work. I have a apc back-ups pro 1500. Im trying to get the current wattage load but the variable on their site is not working…
