Help setting up slider to send uart comands
Hello there.
I need to create a slider from 6 to 32 that each value that i select in the slider, i can send to uart as like this: - uart.write: “:0110001400010203E8ED\r\n”
The code is to create a slider that my wife can change the charging power. I have a button but prefer a slider, but i am having a hard time to learn how to change it. I have no coding skills.
Currently, i have like this (sorry but this way was the best that i could do it, at that time):
button:
    on_press:
      - uart.write: ":0110001400010203E8ED\r\n"
    on_press:
      - uart.write: ":01100014000102008652\r\n"
    on_press:
      - uart.write: ":0110001400010200A731\r\n"
    on_press:
      - uart.write: ":0110001400010200C810\r\n"
    on_press:
      - uart.write: ":0110001400010200EAEE\r\n"
    on_press:
      - uart.write: ":01100014000102010BCC\r\n"
    on_press:
      - uart.write: ":01100014000102014D8A\r\n"
    on_press:
      - uart.write: ":01100014000102019047\r\n"
Thank you for all the help!
Try with template number, it’s slider as default.
number:
    optimistic: true
    min_value: 6
    max_value: 32
    step: 1
    on_value:
      then:
        - lambda: |-
            if (x == 6) {
              id(my_uart).write_str(":01100014000102008652\r\n");
            } else if (x == 7) {
              id(my_uart).write_str(":0110001400010200A731\r\n");
            } else if
                # and so on...
ps. you have to give id to your uart component.
