Hi all.
After upgrade to 2022.5 version my setup ran into problem ,that looks like hassos cannot reach internet.
First symptom was that HACS very often had:
Background tasks pending
Some repositories might not show until this is completed
Ignored that, after restart this warning dissapeared. Then when I tried to update addons from HACS they did not update any more, and in logs were this:
Download failed - Cannot connect to host objects.githubusercontent.com:443 ssl:default [Try again]
Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 1154, in _create_direct_connection
hosts = await asyncio.shield(host_resolved)
File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 880, in _resolve_host
addrs = await self._resolver.resolve(host, port, family=self._family)
File "/usr/local/lib/python3.9/site-packages/aiohttp/resolver.py", line 33, in resolve
infos = await self._loop.getaddrinfo(
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 856, in getaddrinfo
return await self.run_in_executor(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/socket.py", line 954, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/config/custom_components/hacs/base.py", line 605, in async_download_file
File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 535, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 542, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 907, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 1166, in _create_direct_connection
raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host objects.githubusercontent.com:443 ssl:default [Try again]
But on HA core startup, when HACS has started, it successfully scans for updates, and offer them for install.
Also realized my command line sensors stopped working, like:
- platform: rest
resource: http://icanhazip.com
value_template: '{{ value }}'
scan_interval: 3600
gives me error:
Error fetching data: http://icanhazip.com failed with [Errno -3] Try again
Also find out that System Health shows me unreachable endpoints:
Home Assistant Community Store
| GitHub API | ok |
| GitHub Content | unreachable |
| GitHub Web | unreachable – more info |
| GitHub API Calls Remaining | 5000 |
Home Assistant Cloud
| Logged In | false |
| Reach Certificate Server | unreachable |
| Reach Authentication Server | unreachable |
| Reach Home Assistant Cloud | ok |
Home Assistant Supervisor
Version API unreachable
Spotify
Spotify API endpoint reachable unreachable
Spotify
ha dns info gives me:
fallback: true
host: 172.30.32.3
llmnr: true
locals:
- dns://8.8.8.8
- dns://1.1.1.1
mdns: true
servers: []
update_available: false
version: 2022.04.1
version_latest: 2022.04.1
Intersting part that, when I ping gihub.com via hassio terminal it gives me bad address, when I ping githubs IP it pings, and afterwards I can ping host github.com
ping github.com -c 5
ping: bad address 'github.com'
ping:140.82.121.4 -c -5
PING 140.82.121.4 (140.82.121.4): 56 data bytes
64 bytes from 140.82.121.4: seq=0 ttl=54 time 31.832 ms
PING 140.82.121.3 (140.82.121.3): 56 data bytes
Also tried to set IP static not dhcp( with reservation), Rebooted/upgraded Mikrotik router, restarted Hassos Host (now v7.6), had instlalled adblock guard addon (but it was disabled all the time) removed it.
I have run out of Ideas it it all is really weird. I have not set up any ACLs in my netowork, and with this network setup my HA Core has ran for 4 years without any problems till now.
Installed test HA Core instance on Hyper V, upgraded it to latest HA Core and on this machine there is no such a issue.
PLease help me to resolve this strange issue, as it is driving me nuts
about page:
Home Assistant Core 2022.5.5
Home Assistant Supervisor 2022.05.3
Home Assistant OS 7.6
Kernel version 5.10.103-v8
Agent version 1.2.1
Time is correct on Homeasistant Core
It definetly looks like DNS issue
