HELP! Snapshot to mobile notification
Hi guys,
I recently transitioned from Smartthings and doing my first steps in yaml; right now trying to keep it as simple as possible, since I have no programming background.
Basic lighting and sensor automations are done, but now I am trying to get a snapshot from a camera pointing at the frontdoor (triggered by the door’s contact sensor change of state) to be sent to my iphone as a notification.
I created a folder at /config/snapshots and, in the config.yaml, I pointed the external_dirs to that folder. This worked well because the folder is filled with snapshots from my recent tests.
However, somehow, I am not beeing able to send the image to the iphone after the snapshot is taken.
My current automation is like this:
I mean, I receive the notification, but the image I receive is like a media player, all black, without any media to play. Is the data section in the notification part not well written?
Any help will be very appreciated :slight_smile:
Thank you very much!
Filipe
I think you need to place the snapshot in the /config/www directory (or a subfolder within that location) and then the notification should refer to /local (plus whatever subfolder you used, if any).
https://www.home-assistant.io/integrations/generic/#local-image
Thanks for the suggestion, but didn’t work…
This is the result after changing to the www folder:
Any idea?
