Is it possible to have nested folders in yaml config
If I understood which one to use I wouldn’t be asking…
I have managed to already split my config but I couldn’t find anything on nested or sub folders in a folder a folder??
Dont get confused with packages and the rest
packages have everything in one file
eg
I build a catfeeder
so my config
packages: !include_dir_named packages
then have a folder in side the packages folder call Cat-feeder
which has everything in it related to it
but my MQTT: stuff that I don’t want to package
and
that what so cool about HA
once you understand the rules you can make them fit your needs
i
Yes. If you’re not using packages, use !include dir_merge_list foo
and you can have nested folders under foo
. Top of my configuration.yaml
looks like this:
automation manual: !include_dir_merge_list automations
binary_sensor: !include binary_sensors.yaml
climate: !include climate.yaml
group: !include groups.yaml
mqtt:
sensor: !include_dir_merge_list mqtt/sensors
binary_sensor: !include_dir_merge_list mqtt/binary_sensors
switch: !include_dir_merge_list mqtt/switches
proximity: !include proximity.yaml
rest: !include_dir_merge_list rest
script: !include scripts.yaml
sensor: !include_dir_merge_list sensors
and, for example, I have automations/hot-water/hot-water-on.yaml
containing an automation and rest/printer.yaml
with a few sensor definitions in. I could choose to create a folder structure under rest
and that would work with a reload and no further changes to configuration.yaml
