Help! SSH - Can't see specific folders (/etc/udev/ or /dev/serial/)
EDIT: Fixed my USB mapping issue, but still can’t see those folders. Oh well, will leave this up in case anyone runs into a similar issue!
Hello All,
I’ve got the SSH add-on installed, and I can connect to it via an RSA key I set in the settings of the add-on and in PuTTy. I connect as root user and the RSA key, and I can see folders including the folder that contains configuration.yaml, etc.
I’m trying to look into:
/etc/udev/
or /dev/serial/
but I always get “No such file or directory”.
I’m trying to undo a symlink I had when I defined a persistent name for USB zwave (had followed this guide: http://hintshop.ludvig.co.nz/show/persistent-names-usb-serial-devices/).
I don’t know what changed, but I can no longer see these folder when navigating through puTTy… what’s driving me nuts is I had accessed those directories to create a .rules file months (and various updates) ago. Any help would be appreciated, especially if I’m doing something silly.
This 0.70 update broke my Zwave functionality entirely, sigh…
