Help, suddenly it didn't work anymore zigbee2mqtt
suddenly it didn’t work anymore
my configuration
Home Assistant OS 7.0
Home Assistant 2021.12.0
Zigbee2mqtt
Current version: 1.22.1-1
lumi.gateway.mgl03 ZNDMWG03LM
da Xiaomi
Firmware: 1.5.1_0032
`data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
  base_topic: zigbee2mqtt
serial:
  port: tcp://192.168.1.86:8888
  adapter: ezsp
advanced:
  log_level: info
  pan_id: 6754
  channel: 11
  network_key:
    - 1
    - 3
    - 5
    - 7
    - 9
    - 11
    - 13
    - 15
    - 0
    - 2
    - 4
    - 6
    - 8
    - 10
    - 12
    - 13
  availability_blocklist: []
  availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
  port: 8099
experimental: {}
availability: false
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: '-d -d'
  log: false
LOG:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[13:34:55] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[13:34:55] INFO: MQTT available, fetching server detail ...
[13:34:56] INFO: MQTT server settings not configured, trying to auto-discovering ...
[13:34:56] INFO: Configuring 'mqtt://core-mosquitto:1883' mqtt server
[13:34:56] INFO: MQTT credentials not configured, trying to auto-discovering ...
[13:34:56] INFO: Configuring'addons' mqtt user
[13:34:56] INFO: Previous config file found, checking backup
[13:34:56] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[13:34:56] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[13:34:57] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start
> node index.js
Zigbee2MQTT:info  2021-12-12 13:35:00: Logging to console and directory: '/config/zigbee2mqtt/log/2021-12-12.13-34-59' filename: log.txt
Zigbee2MQTT:info  2021-12-12 13:35:00: Starting Zigbee2MQTT version 1.22.1 (commit #unknown)
Zigbee2MQTT:info  2021-12-12 13:35:00: Starting zigbee-herdsman (0.13.176)
What does not work anymore ? Your devices, or the front-end ? Or both ?
no nothing, no devices are detected
