Hi All,
I’m having an issue when send an IR code I’ve learnt via the Broadlink RM Pro.
I am using Both RF and IR codes to control my Aircon and some TC2 Power switches and these are working Fine. But when I learn the IR sequence for My Braun TV. I recieve the Following when doing a Check Config.
“Configuration invalidTesting configuration at /config 2018-02-17 19:48:02 ERROR (SyncWorker_0) [homeassistant.util.yaml] mapping values are not allowed here in “/config/configuration.yaml”, line 192, column 19 2018-02-17 19:48:02 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: mapping values are not allowed here in “/config/configuration.yaml”, line 192, column 19”
Here is a copy of what is in my configuration.yaml
- platform: broadlink
host: 192.168.0.92
mac: '34:ea:34:8e:f8:8a'
timeout: 15
switches:
air_con_kelvinator_23dry:
friendly_name: "Living Room 23 Dry"
command_on: 'JgDKAI6REDYRExE1ETYREhETETURExESEjUREhETETUSNRESETYREhETERIRNhE1ETYSNRI0ETYRNRI1ERISEhESERMREhETETUSEhI0EhIRNRISEhERNhESETYREhE2EhIQNhE2EKyPkBE1ERMRNRE2ERMREhE1EhIREhE2EhESEhE1EjUREhE2EhETERESETYSNRI0EjUSNBI1EjURNRISERIREhEUEBIRFBA1EhIRNRISETUSEhESETYSEhA2EhIRNRISEDYSNREADQUAAAAAAAAAAAAAAAAAAA=='
command_off: 'JgDKAI6REjQQFBI0EDcQExISEjQSEhATEDcSERISEjQSNRESETYSERE2ETUSNRI1EhETNBI0EzQREhETExATERI0ExEREhM0EzMRNhESExEREhMRExATERMQExASNRM0ETURNhMzEauPkRI0EhIQNhI1EhERExE1EhISERE2ERIRExE1ETYSERE2ERISNRE2EjQTNBESETYRNRE2ERMREhESERMRNRMRERITNBE2ETURExMQERIRExESERMREhETETURNhE1ETYRNhEADQUAAAAAAAAAAAAAAAAAAA=='
living_room_tv:
friendly_name:"Living Room TV"
command_on: 'Uj+EAIiy+m+/JXFf9ZjnThETETURExESEjUREg=='
command_off: 'Uj+EAIiy+m+/JXFf9ZjnThETETURExESEjUREg=='
The AIrcon commands work fine. The “Living Room TV” command_on: causes this error on the Config Check. Is there a character in there that it doesnt like. any clues as to what I’m doing wrong?
