My Syslog files in /var/log are becoming increasingly hard to go through now. Almost every line of the syslog are debug lines from ozw. I haven’t changed any log setting to my knowledge and am using openzwave addon as well as the openzwave beta integration,.
Is there a way to either write these events to another log or more preferably ignore non errors/warnings? I thought the default state in come assistant was info and above? Not debug.
Example:
Sep 19 00:29:40 tower c68f0fe6b088[1869]: debug1: connect_next: host localhost ([::1]:8123) in progress, fd=6#015
Sep 19 00:29:40 tower c68f0fe6b088[1869]: debug1: channel 2: new [127.0.0.1]#015
Sep 19 00:29:40 tower c68f0fe6b088[1869]: debug1: confirm forwarded-tcpip#015
Sep 19 00:29:40 tower c68f0fe6b088[1869]: debug1: channel 2: connected to localhost port 8123#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: client_input_channel_open: ctype forwarded-tcpip rchan 5 win 2097152 max 32768#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: client_request_forwarded_tcpip: listen localhost port 44400, originator 127.0.0.1 port 50140#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: connect_next: host localhost ([::1]:8123) in progress, fd=7#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: channel 3: new [127.0.0.1]#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: confirm forwarded-tcpip#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: channel 3: connected to localhost port 8123#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: client_input_channel_open: ctype forwarded-tcpip rchan 3 win 2097152 max 32768#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: client_request_forwarded_tcpip: listen localhost port 44400, originator 127.0.0.1 port 50142#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: connect_next: host localhost ([::1]:8123) in progress, fd=8#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: channel 4: new [127.0.0.1]#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: channel 1: free: 127.0.0.1, nchannels 5#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: channel 4: connected to localhost port 8123#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: channel 2: free: 127.0.0.1, nchannels 4#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: channel 3: free: 127.0.0.1, nchannels 3#015
Sep 19 00:29:41 tower c68f0fe6b088[1869]: debug1: channel 4: free: 127.0.0.1, nchannels 2#015
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.634 CDT] [ozw.library] [debug]: Detail - Node: 13 Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0d, 0x0a, 0x32, 0x02, 0xa1, 0x64, 0x00, 0x01, 0xd7, 0xc2, 0x00, 0x00, 0x0d
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.634 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.637 CDT] [ozw.library] [info]: Info - Node: 13 Received Meter Report for Electric - V (1) with Units V (4) on Index 4: 120.770
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.637 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.640 CDT] [ozw.library] [debug]: Detail - Node: 13 Value Updated: old value=120.615, new value=120.770, type=decimal
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.640 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.642 CDT] [ozw.library] [debug]: Detail - Node: 13 Changes to this value are not verified
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.642 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.645 CDT] [ozw.library] [debug]: Detail - Node: 13 Value Updated: old value=false, new value=false, type=bool
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.645 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.647 CDT] [ozw.library] [debug]: Detail - Node: 13 Changes to this value are not verified
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.648 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.650 CDT] [ozw.library] [debug]: Detail - Node: 13 Notification: ValueChanged CC: COMMAND_CLASS_METER Instance: 1 Index: 4
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.650 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.653 CDT] [ozw.library] [debug]: Detail - Node: 13 Notification: ValueRefreshed CC: COMMAND_CLASS_METER Instance: 1 Index: 256
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.653 CDT] [ozw.notifications] [debug]: Notification pvt_valueChanged: 1125900129959954 Thread: 0xffffb3a16e38
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.653 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.654 CDT] [ozw.mqtt.publisher] [debug]: Publishing Event valueChanged: 1125900129959954
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.656 CDT] [ozw.notifications] [debug]: Notification pvt_valueRefreshed: 72057594261045264 Thread: 0xffffb3a16e38
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.658 CDT] [ozw.mqtt.publisher] [debug]: Publishing Event valueRefreshed: 72057594261045264
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.733 CDT] [ozw.library] [debug]: Detail - Node: 13 Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0d, 0x0a, 0x32, 0x02, 0xa1, 0x6c, 0x00, 0x00, 0x00, 0x1d, 0x00, 0x00, 0x0c
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.733 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.736 CDT] [ozw.library] [info]: Info - Node: 13 Received Meter Report for Electric - A (1) with Units A (5) on Index 5: 0.029
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.736 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.738 CDT] [ozw.library] [debug]: Detail - Node: 13 Value Updated: old value=0.029, new value=0.029, type=decimal
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.738 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.741 CDT] [ozw.library] [debug]: Detail - Node: 13 Changes to this value are not verified
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.741 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.744 CDT] [ozw.library] [debug]: Detail - Node: 13 Value Updated: old value=false, new value=false, type=bool
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.744 CDT] [ozw.logging] [debug]: popping Log Mesages
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.746 CDT] [ozw.library] [debug]: Detail - Node: 13 Changes to this value are not verified
Sep 19 00:29:45 tower 1babf4c77b51[1869]: [20200919 0:29:45.746 CDT] [ozw.logging] [debug]: popping Log Mesages
