Help! Template Sensor
Hi folks,
I got myself a zwave door sensor, and have it working. I’m trying to use a template so HA displays open / closed, rather that 22 / 23 that the sensor sends. I’m not a programmer, and so some of this is beyond me. Thanks to youtube, I’ve gotten this far.
    sensors:
    kitchen_door_2_status:
      friendly_name: "Kitchen door 2"
      value_template: >-
        {% if is_state("sensor.aeon_labs_zw120_door_window_sensor_gen5_access_control_2", "23")%}
          Closed
        {% elif is_state("sensor.aeon_labs_zw120_door_window_sensor_gen5_access_control_2", "22")%}
          Open
        {% else %}
          Unknown
        {% endif %}
While the template editor doesn’t seem to have a problem with it, I performed a config check and the system returned the following;
Invalid config for [sensor.template]: expected dictionary for dictionary value @ data[‘sensors’]. Got None. (See ?, line ?)
Can anyone see what I’m doing wrong? I’m assuming everything is wrong at this stage, but gotta start somewhere I suppose.
The other way is to put three backticks ( ` <-- this character, above the TAB key usually) on an empty line, hit ENTER, paste your code, ENTER again, then three more backticks.
your spacing or indentation is wrong at or around the sensors line.
  sensors:
      value_template: >-
        {% if is_state("sensor.aeon_labs_zw120_door_window_sensor_gen5_access_control_2", "23") %}
        Closed
        {% elif is_state("sensor.aeon_labs_zw120_door_window_sensor_gen5_access_control_2", "22") %}
        Open
        {% else %}
        Unknown
        {% endif %}
Thank you! I’d been looking at it for so long, I couldn’t see anything anymore! System check says it’s cool now.
