I’m trying to build a template sensor that reads the state of two sensors but I’m not sure it it’s possible and, if it is, how to acomplish.
I’ve a sensors.yaml file and and I have two binary sensors. I want that if sensor A is off and sensor B is off, this new sensor state is OFF. If sensors A and B are on, then, this sensor should be ON. any other state (off/on or on/off), it stays as it was before.
I’ve tried this, but I’m getting erros:
sensors:
laststate:
friendly_name: "Last State"
value_template: >-
{% if is_state('binary_sensor.sensor_portao_da_garagem_fechado', 'off') and is_state('binary_sensor.sensor_portao_da_garagem_aberto,'off') %}
off
{% elif is_state('binary_sensor.sensor_portao_da_garagem_fechado', 'on') and is_state('binary_sensor.sensor_portao_da_garagem_aberto,'on') %}
on
{% endif %}
Can someone give me a hint on this?
Thanks in advance
You’re only obligated to use it when you have a condition that can be met that is not in your if and elif statements. If you didn’t add that else to the template, it wouldn’t retain the previous state, it would have been blank because the code finished without an output.
