Hi, i tryed to configure my samsung tv (model ks7000) without success. For me would be enough to be able to switch it on or off. This is my config with latest ha on Hassbian:
2019-01-22 21:44:16 ERROR (MainThread) [homeassistant.helpers.entity] Update for media_player.tv_soggiorno fails
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 221, in async_update_ha_state
await self.async_device_update()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 349, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/media_player/samsungtv.py", line 130, in update
self.send_key("KEY")
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/media_player/samsungtv.py", line 151, in send_key
self.get_remote().control(key)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/media_player/samsungtv.py", line 136, in get_remote
self._remote = self._remote_class(self._config)
File "/srv/homeassistant/lib/python3.5/site-packages/samsungctl/remote.py", line 11, in __init__
self.remote = RemoteWebsocket(config)
File "/srv/homeassistant/lib/python3.5/site-packages/samsungctl/remote_websocket.py", line 28, in __init__
self.connection = websocket.create_connection(url, config["timeout"])
AttributeError: module 'websocket' has no attribute 'create_connection'
Probably the problem is that there is only one SamsungTV component and there are lots of different Samsung TV models. Every series react different to the HA component. Actually there should be a different component for each series (or one component for which you can define your model).
I have a KS7000 too and I am using an old version (I think the 0.80 version) of the Samsungtv component as a custom component. Actually I am not using HA to control the TV but I am using the TV state (on/off) to control light scenes.
For me would be enough to switch the tv state on or off… could you please share your version so I can try if it works better? Seems there’s low interest in the samsungtv component from HA…
Hi not sure where you got with this, but I managed to get some functionality with mine. I am using the latest custom code out of HACS with the following config
