I have the following Python code, but apart from it works when restarting the Home-Assistant, the entities does not get updated anymore.
How do I place the subscription to the mqtt, in such a way, that the entities are updated, everytime the mqtt server sends a message.
Only thing that happens now is the async-Update, updates the state with the initial value, and that is hopeless
As you can see from the commented out statements, I had it fully working reading from a file, but the mqtt response have me at a loss.
Your help would be highly apreciated, as I am an experienced programmer, but Python is so different, that I have not fully grasped it yet.
This is the sensor.py program.
"""Support for the LiLyGo TIGO HIgrow sensor."""
import logging
import json
# import time
import paho.mqtt.client as mqtt
from datetime import timedelta
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
from homeassistant.const import (
CONF_NAME, CONF_MONITORED_CONDITIONS
from homeassistant.components.sensor import PLATFORM_SCHEMA
from homeassistant.helpers.entity import Entity
_LOGGER = logging.getLogger(__name__)
MIN_TIME_BETWEEN_UPDATES = timedelta(seconds=1000)
# Key: ['json_key', 'name', 'unit', 'icon']
SENSOR_TYPES = {
'date': ['date','date', ' ', 'mdi:calendar'],
'time':['time', 'time', ' ', 'mdi:clock'],
'sleep5Count':['sleep5Count','sleep5Count', ' ', 'mdi:counter'],
'bootCount':['bootCount','bootCount', ' ', 'mdi:counter'],
'lux':['lux','lux','lumen', 'mdi:weather-sunny'],
'temp':['temp', 'temp', 'C', 'mdi:thermometer'],
'humid':['humid', 'humid', '%', 'mdi:percent'] ,
'soil':['soil', 'soil', '%', 'mdi:water-percent'],
'salt':['salt', 'salt', 'q', 'mdi:bottle-tonic'],
'bat':['bat', 'bat', 'V', 'mdi:battery'],
'rel':['rel', 'rel', ' ', 'mdi:alert-decagram'],
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Optional(CONF_NAME, default='TIGO_HIgrow_Dendrobium'): cv.string,
vol.Optional(CONF_MONITORED_CONDITIONS, default=list(SENSOR_TYPES)):
vol.All(cv.ensure_list, [vol.In(SENSOR_TYPES)])
ATTRIBUTION = "LILYGO HI-Grow Sensor"
async def async_setup_platform(hass, config, async_add_entities, discovery_info=None):
"""Set up the TIGO HIgrow sensor."""
name = config.get(CONF_NAME)
print(name)
# try:
# HIgrow_data = open('dendrobium.json', 'r').read()
# except ValueError as err:
# _LOGGER.error("Received data error from TIGO_HIgrow: %s", err)
# return
def on_message(client, userdata, msg):
m_decode=str(msg.payload.decode("utf-8","ignore"))
print("data Received type",type(m_decode))
print("data Received",m_decode)
print("Converting from Json to Object")
m_in=json.loads(m_decode)
print(type(m_in))
Temperatur = m_in["temp"]["temp"], "C"
print("broker 1 temp = ", Temperatur)
# print("broker 1 soil = ",m_in["soil"]["soil"], "%")
HIgrow_data=m_decode
print("HIgrow_data 0")
print(HIgrow_data)
dev = []
for HIgrow in config[CONF_MONITORED_CONDITIONS]:
convert_units = SENSOR_TYPES[HIgrow][2]
sensor = name + '_' + SENSOR_TYPES[HIgrow][0]
dev.append(TIGO_HIgrow(HIgrow_data, name, sensor, HIgrow, convert_units))
async_add_entities(dev, True)
brokers_out={"broker1":"192.168.1.64"}
topic = name
client=mqtt.Client(name)
print("after client.on")
# HIgrow_data=str(msg.payload.decode("utf-8","ignore"))
print("Connecting to broker ",brokers_out["broker1"])
client.connect(brokers_out["broker1"])
print("after client.connect")
client.loop_start()
print("subscribe")
client.subscribe(topic)
client.on_message=on_message
# time.sleep(10)
# client.loop_stop()
# client.disconnect()
class TIGO_HIgrow(Entity):
"""Representation of a Sensor."""
def __init__( self, HIgrow_data, sensor, name, HIgrow, convert_units):
"""Initialize the sensor."""
# _LOGGER.debug("Init self ")
self._name = name
self._sensor = sensor
self._HIgrow = HIgrow
self._convert_units = SENSOR_TYPES[HIgrow][3]
self._units = convert_units
self._json_key = SENSOR_TYPES[HIgrow][0]
self._icon = SENSOR_TYPES[HIgrow][3]
self._data = HIgrow_data
self._state = None
print("self data ", self._data)
# self._rain_today = 0.00
@property
def name(self):
"""Return the name of the sensor."""
return self._name
@property
def state(self):
"""Return the state of the sensor."""
return self._state
@property
def icon(self):
"""Icon to use in the frontend, if any."""
return self._icon
@property
def unit_of_measurement(self):
"""Return the unit of measurement of this entity, if any."""
if self._convert_units:
return self._units
else:
return self._unit
async def async_update(self, utcnow=None):
"""Get the latest data from Tgrow sensor and update the states."""
#with open('dendrobium.json', 'r') as HIgrow_json:
# Prevent errors when data not present at night but retain long term states
print("Device: {}".format(self._HIgrow))
#self._data = json.loads(self._data)
print("Data: ", self._data)
if self._data and (self._json_key in self._data):
state = self._data[self._json_key][self._json_key]
print("state %s", state)
self._state = str(state)
