Hello I have NSPanel with this code:
How I can grab temperature from my external temperature sensor ?
I what disable internal NTC sensor because it is very inaccurate, and therefore I would like to take advantage of a xiaomi sensor currently in use present in HA.
can you help me to edit the code in use?
esphome:
comment: Sonoff NSPanel 01 - Ingresso
esp32:
board: esp32dev
wifi:
ssid: "WiFi"
password: "12345678901234567890"
manual_ip:
static_ip: 192.168.1.25
gateway: 192.168.1.1
subnet: 255.255.255.0
dns1: 8.8.8.8
dns2: 1.1.1.1
time:
- platform: homeassistant
logger:
on_message:
level: DEBUG
then:
ota:
web_server:
# HTTP Request component needed for wttr.in weather web query
http_request:
useragent: esphome/device
timeout: 5s
substitutions:
# Unique ID for Sensors.
switch_id: "nsp01"
friendly_name: "NSPanel 01"
wttr_location: "ipswich"
uart:
tx_pin: 16
rx_pin: 17
baud_rate: 115200
# Use Local modified NSPanel component
external_components:
- source: github://pr#2702
components: ["nspanel"]
refresh: 0s
- source: github://pr#3331
components: ["json"]
# - source:
# type: local
# path: components
# components: ["nspanel"]
# refresh: 0s
# Update Weather Hourly
interval:
- interval: 60min
then:
- script.execute: nspanel_weather
# NSPanel Component for access to panel.
# Updates temperature, date, time, Relay indicators
# Provides JSON interface to panel
nspanel:
time_id: homeassistant_time
temperature: ${switch_id}_temperature
eco_mode_switch: ${switch_id}_eco_mode
screen_power_switch: ${switch_id}_screen_power
relays:
- ${switch_id}_relay_1
- ${switch_id}_relay_2
on_json_message:
then:
# Widget 1 (type:0x86 id:light7)
- if:
condition:
lambda: 'return (type == 0x86 && root.containsKey("id") && strcasecmp(root["id"], "light7") == 0);'
then:
- if:
condition:
lambda: 'return (root["params"].containsKey("switch") && root["params"]["switch"] == "on");'
then:
- homeassistant.service:
service: light.turn_on
entity_id: light.dim_09_light
- if:
condition:
lambda: 'return (root["params"].containsKey("switch") && root["params"]["switch"] == "off");'
then:
service: light.turn_off
- if:
condition:
lambda: 'return (root["params"].containsKey("white"));'
then:
brightness: !lambda 'return int(root["params"]["white"]["br"].as<float>() / 100 * 255);'
# Widget 2 (type:0x86 id:wled_test)
- if:
condition:
lambda: 'return (type == 0x86 && root.containsKey("id") && strcasecmp(root["id"], "wled_test") == 0);'
then:
- if:
condition:
lambda: 'return (root["params"].containsKey("switch") && root["params"]["switch"] == "on" && !root["params"].containsKey("bright"));'
then:
entity_id: light.wled_test
- if:
condition:
then:
- if:
condition:
lambda: 'return (root["params"].containsKey("bright"));'
then:
service: script.set_light_on_rgb
entity_name: light.wled_test
brightness: !lambda 'return int(root["params"]["bright"].as<float>() / 100 * 255);'
red: !lambda 'return root["params"]["colorR"].as<int>();'
green: !lambda 'return root["params"]["colorG"].as<int>();'
blue: !lambda 'return root["params"]["colorB"].as<int>();'
# Widget 3 (type:0x86 id:plug_09)
- if:
condition:
lambda: 'return (type == 0x86 && root.containsKey("id") && strcasecmp(root["id"], "plug_09") == 0);'
then:
- if:
condition:
then:
service: switch.turn_on
entity_id: switch.plug_09_relay_1
- if:
condition:
then:
service: switch.turn_off
# Widget 4 (type:0x86 id:group_01 = plug_08 + plug_11)
- if:
condition:
lambda: 'return (type == 0x86 && root.containsKey("id") && strcasecmp(root["id"], "group_01") == 0);'
then:
- if:
condition:
lambda: 'return (root["params"].containsKey("switches") && root["params"]["switches"][0]["switch"] == "on");'
then:
entity_id: switch.plug_08_relay_1
- if:
condition:
lambda: 'return (root["params"].containsKey("switches") && root["params"]["switches"][0]["switch"] == "off");'
then:
- if:
condition:
lambda: 'return (root["params"].containsKey("switches") && root["params"]["switches"][1]["switch"] == "on");'
then:
entity_id: switch.plug_11_relay_1
- if:
condition:
lambda: 'return (root["params"].containsKey("switches") && root["params"]["switches"][1]["switch"] == "off");'
then:
# Widget 5 (type:0x86 id:test_curtain)
- if:
condition:
lambda: 'return (type == 0x86 && root.containsKey("id") && strcasecmp(root["id"], "test_curtain") == 0);'
then:
- if:
condition:
then:
service: cover.open_cover
entity_id: cover.test_curtain
- if:
condition:
then:
service: cover.close_cover
- if:
condition:
lambda: 'return (root["params"].containsKey("switch") && root["params"]["switch"] == "pause");'
then:
service: cover.stop_cover
- if:
condition:
lambda: 'return (root["params"].containsKey("setclose"));'
then:
service: input_number.set_value
entity_id: input_number.test_curtain_pos
value: !lambda 'return 100 - root["params"]["setclose"].as<int>();'
# Thermostat (type:0x84)
- if:
condition:
lambda: 'return (type == 0x84);'
then:
- if:
condition:
lambda: 'return (root.containsKey("ATCEnable") && root["ATCEnable"] == 1);'
then:
service: climate.turn_on
entity_id: sensor.temperature_158d00010f993f
- if:
condition:
lambda: 'return (root.containsKey("ATCEnable") && root["ATCEnable"] == 0);'
then:
service: climate.turn_off
- if:
condition:
lambda: 'return (root.containsKey("ATCExpect0"));'
then:
service: climate.set_temperature
temperature: !lambda 'return root["ATCExpect0"].as<int>();'
hvac_mode: heat
output:
- platform: ledc
pin:
number: 21
rtttl:
output: ${switch_id}_buzzer_out
api:
services:
# Expose "send_json" to Home Assistant for scripts/testing
- service: send_json
variables:
my_type: int
my_json: string
then:
- lambda: 'id(nspanel1).send_json_command(my_type,my_json);'
switch:
# Restart Switch in HA
- platform: restart
- platform: gpio
# Panel Left Hand relay
name: ${switch_id} Relay 1
pin:
number: 22
- platform: gpio
# Panel Right Hand relay
name: ${switch_id} Relay 2
pin:
number: 19
- platform: gpio
# Panel Screen Power
name: ${switch_id} Screen Power
entity_category: config
pin:
number: 4
inverted: true
restore_mode: ALWAYS_OFF
on_turn_on:
# Initiliase Screen - These timings could be more aggressive
then:
- delay: 6s
- script.execute: nspanel_init
- delay: 3s
# Must send Wifi State for widgets to update (particulalry after power-on of screen only
# code taken from within NSPanel component code
- lambda: |-
uint8_t rssi = 0;
rssi = (wifi::global_wifi_component->wifi_rssi() * -1) / 20.0f;
std::string json_str = json::build_json([rssi](JsonObject root) {
root["wifiState"] = "connected";
root["rssiLevel"] = rssi;
id(nspanel1).send_json_command(0x85, json_str);
# Template switch to enable/disable screen dimming
name: ${switch_id} Energy Saving Mode
restore_state: true
optimistic: true
binary_sensor:
# NS Panel Hard Switches
- platform: gpio
name: ${switch_id} Left Button
pin:
number: 14
inverted: true
on_click:
- switch.toggle: ${switch_id}_relay_1
- platform: gpio
name: ${switch_id} Right Button
pin:
number: 27
inverted: true
on_click:
- switch.toggle: ${switch_id}_relay_2
# HA Tracking sensors for device states
# Update nspanel on state change
on_press:
then:
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"id\":\"light7\",\"params\":{\"switch\":\"on\"}}");'
on_release:
then:
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"id\":\"light7\",\"params\":{\"switch\":\"off\"}}");'
on_press:
then:
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"id\":\"wled_test\",\"params\":{\"switch\":\"on\"}}");'
on_release:
then:
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"id\":\"wled_test\",\"params\":{\"switch\":\"off\"}}");'
on_press:
then:
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"id\":\"plug_09\",\"params\":{\"switch\":\"on\"}}");'
on_release:
then:
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"id\":\"plug_09\",\"params\":{\"switch\":\"off\"}}");'
on_press:
then:
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"id\":\"group_01\",\"params\":{\"switches\":[{\"switch\":\"on\",\"outlet\":0}]}}");'
on_release:
then:
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"id\":\"group_01\",\"params\":{\"switches\":[{\"switch\":\"off\",\"outlet\":0}]}}");'
on_press:
then:
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"id\":\"group_01\",\"params\":{\"switches\":[{\"switch\":\"on\",\"outlet\":1}]}}");'
on_release:
then:
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"id\":\"group_01\",\"params\":{\"switches\":[{\"switch\":\"off\",\"outlet\":1}]}}");'
# Extra sensor to keep track of plug uptime
- platform: uptime
name: ${switch_id} Uptime Sensor
# Wifi Signal
- platform: wifi_signal
name: "${switch_id} WiFi Signal Sensor"
update_interval: 60s
# nspanel related temperature sensors
- platform: adc
pin: 38
update_interval: 10s
attenuation: 11db
- platform: resistance
sensor: ${switch_id}_ntc_source
configuration: DOWNSTREAM
resistor: 11.2kOhm
- platform: ntc
sensor: ${switch_id}_resistance_sensor
calibration:
b_constant: 3950
reference_temperature: 25°C
reference_resistance: 10kOhm
name: "${switch_id} Temperature"
# Home Assistant Light State Sensors to update panel
# Light light.dim_09_light brightness (0-255)
attribute: brightness
on_value:
then:
- script.execute: ha_dim_09_light_update
# Light light.wled_test brightness (0-255)
on_value:
then:
- script.execute: ha_wled_test_update
attribute: current_position
on_value:
then:
- script.execute: ha_test_curtain_update_pos
# Thermostat set temp
name: ${switch_id} Climate Temp
attribute: temperature
internal: true
on_value:
then:
- script.execute: ha_thermostat_update_temp
text_sensor:
# Text Sensors to track attirbutes from HA (HA -> Panel)
name: "HA wled_test RGB"
attribute: rgb_color
internal: false
on_value:
then:
name: "Test Curtain State"
internal: true
on_value:
then:
- script.execute: ha_test_curtain_update_state
internal: true
on_value:
then:
- script.execute: ha_thermostat_update_state
script:
- id: ha_dim_09_light_update
then:
- lambda: |-
if (id(dim_09_light).state) {
int i_brightness = int(id(dim_09_light_bright).state / 255 * 100);
id(nspanel1).send_json_command(0x86,"{\"id\":\"light7\",\"params\":{\"switch\":\"on\",\"ltype\":\"white\",\"white\":{\"br\":" + to_string(i_brightness) + "}}}");
} else {
- id: ha_wled_test_update
# Decode RGB Attribute ((r,g,b) and send to panel
then:
- lambda: |-
if (id(wled_test_light).state) {
int i_brightness = int(id(wled_test_bright).state / 255 * 100);
std::string s = id(wled_test_rgb).state;
std::string r = "255";
std::string g = "0";
std::string b = "0";
int p1 = s.find(",");
if (p1 > 0) {
int p2 = s.find(",",p1+1);
r = s.substr(1, p1-1).erase(0,s.find_first_not_of(" "));
g = s.substr(p1+2,p2-p1-2).erase(0,s.find_first_not_of(" "));
b = s.substr(p2+2,s.length()-2).erase(0,s.find_first_not_of(" "));
id(nspanel1).send_json_command(0x86,"{\"id\":\"wled_test\",\"params\":{\"switch\":\"on\",\"light_type\":1,\"mode\":1,\"bright\":" + to_string(i_brightness) + ",\"colorR\":" + to_string(r) + ",\"colorG\":" + to_string(g) + ",\"colorB\":" + to_string(b) + "}}");
} else {
- id: ha_plug_09_update
then:
- lambda: |-
if(id(plug_09_switch).state) {
} else {
- id: ha_plug_08_update
then:
- lambda: |-
if(id(plug_08_switch).state) {
} else {
- id: ha_plug_11_update
then:
- lambda: |-
if(id(plug_11_switch).state) {
} else {
- id: ha_test_curtain_update_state
then:
- lambda: |-
if(id(test_curtain_state).state == "open") {
id(nspanel1).send_json_command(0x86,"{\"id\":\"test_curtain\",\"params\":{\"switch\":\"on\"}}");
} else {
id(nspanel1).send_json_command(0x86,"{\"id\":\"test_curtain\",\"params\":{\"switch\":\"off\"}}");
- id: ha_test_curtain_update_pos
then:
- lambda: |-
id(nspanel1).send_json_command(0x86,"{\"id\":\"test_curtain\",\"params\":{\"setclose\":" + to_string(100 - id(test_curtain_pos).state) + "}}");
- id: ha_thermostat_update_state
then:
# Update Thermostat On/Off
- lambda: |-
if (id(climate_state).state == "heat") {
id(nspanel1).send_json_command(0x84,"{\"ATCEnable\":1}");
} else {
id(nspanel1).send_json_command(0x84,"{\"ATCEnable\":0}");
- id: ha_thermostat_update_temp
then:
# Update Thermostat Temperature
- lambda: |-
if ( (int) id(climate_temp).state > 15 && (int) id(climate_temp).state < 32 && id(climate_state).state == "heat") {
id(nspanel1).send_json_command(0x84,"{\"ATCExpect0\":" + to_string((int) id(climate_temp).state) + "}");
- id: nspanel_init
# Script to initialise panel on full power on (or when screen is powered on from ESP)
then:
# Setup Widgets - must send all 8
# Widget 1
- lambda: |-
id(nspanel1).send_json_command(0x86,"{\"HMI_resources\":[{\"index\":1,\"ctype\":\"device\",\"id\":\"light7\",\"uiid\":52}]}"); id(nspanel1).send_json_command(0x86,"{\"relation\":[{\"ctype\":\"device\",\"id\":\"light7\",\"name\":\"DIM09\",\"online\":1,\"params\":{\"switch\":\"off\",\"ltype\":\"white\",\"white\":{\"br\":0,\"ct\":0}}]}");
# Widget 2
- lambda: |-
id(nspanel1).send_json_command(0x86,"{\"HMI_resources\":[{\"index\":2,\"ctype\":\"device\",\"id\":\"wled_test\",\"uiid\":33}]}");
id(nspanel1).send_json_command(0x86,"{\"relation\":[{\"ctype\":\"device\",\"id\":\"wled_test\",\"name\":\"WLED\",\"online\":1,\"params\":{\"switch\":\"on\"}]}");
# Widget 3
- lambda: |-
id(nspanel1).send_json_command(0x86,"{\"HMI_resources\":[{\"index\":3,\"ctype\":\"device\",\"id\":\"plug_09\",\"uiid\":1}]}");
id(nspanel1).send_json_command(0x86,"{\"relation\":[{\"ctype\":\"device\",\"id\":\"plug_09\",\"name\":\"PLUG09\",\"online\":1,\"params\":{\"switch\":\"on\"}]}");
# Widget 4
- lambda: |-
id(nspanel1).send_json_command(0x86,"{\"HMI_resources\":[{\"index\":4,\"ctype\":\"device\",\"id\":\"group_01\",\"uiid\":2}]}");
id(nspanel1).send_json_command(0x86,"{\"relation\":[{\"ctype\":\"device\",\"id\":\"group_01\",\"name\":\"Plugs\",\"online\":1,\"params\":{\"switches\":[{\"switch\":\"on\",\"outlet\":0},{\"switch\":\"on\",\"outlet\":1}]}");
# Widget 5
- lambda: |-
id(nspanel1).send_json_command(0x86,"{\"HMI_resources\":[{\"index\":5,\"ctype\":\"device\",\"id\":\"test_curtain\",\"uiid\":11}]}");
id(nspanel1).send_json_command(0x86,"{\"relation\":[{\"ctype\":\"device\",\"id\":\"test_curtain\",\"name\":\"Cover\",\"online\":1,\"params\":{\"switch\":\"on\"}]}");
# Widget 6
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"index\":6,\"type\":\"delete\"}");'
# Widget 7
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"index\":7,\"type\":\"delete\"}");'
# Widget 8
- lambda: 'id(nspanel1).send_json_command(0x86,"{\"index\":8,\"type\":\"delete\"}");'
# Update existing Entities / Widgets
- script.execute: ha_plug_09_update
- script.execute: ha_plug_08_update
- script.execute: ha_plug_11_update
# Setup Thermostat
- lambda: 'id(nspanel1).send_json_command(0x84,"{\"HMI_ATCDevice\":{\"ctype\":\"device\",\"id\":\"climate\",\"outlet\":0,\"etype\":\"hot\"}}");'
- lambda: 'id(nspanel1).send_json_command(0x84,"{\"ATCMode\":0}");'
# Update Thermostat
- id: nspanel_weather
# Grab weather status (JSON) from https://wttr.in
then:
- logger.log: "nspanel_weather started"
- lambda: |-
WiFiClientSecure client;
HTTPClient http;
int wicon,wicon_out;
std::string buffer;
// Disable certificate checking
client.setInsecure();
ESP_LOGD("nspanel_weather", "Init Complete");
//use appropriate location - test in browser without "?format=j2" for normal output
http.begin(client,"wttr.in",443,"/${wttr_location}?format=j2",true);
ESP_LOGD("nspanel_weather", "http.begin OK");
http.useHTTP10(true);
int httpCode = http.GET();
ESP_LOGD("nspanel_weather", "http.GET OK");
if (httpCode > 0) {
// http response received
ESP_LOGD("nspanel_weather", "HTTP response code is %i", httpCode);
if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY) {
// setup JSON object for HTTP response
DynamicJsonDocument root(4000);
DeserializationError error = deserializeJson(root, http.getStream());
if (root.containsKey("current_condition")) {
ESP_LOGD("nspanel_weather", "JSON Parse OK");
wicon = int( root["current_condition"][0]["weatherCode"].as<signed int>());
ESP_LOGD("nspanel_weather", "weather code received: %i",wicon);
// Translate wttr.in weather code to use correct nspanel icon
// Mapping from Tasmota nspanel.be code
wicon_out = 30; // Unknown / Default
if (wicon == 113) { wicon_out = 1; } // # Sunny
if (wicon == 116) { wicon_out = 2; } // # PartlyCloudy
if (wicon == 119) { wicon_out = 2; } // # Cloudy
if (wicon == 122) { wicon_out = 7; } // # VeryCloudy
if (wicon == 143) { wicon_out = 11; } // # Fog
if (wicon == 176) { wicon_out = 40; } // # LightShowers
if (wicon == 179) { wicon_out = 24; } // # LightSleetShowers
if (wicon == 182) { wicon_out = 24; } // # LightSleet
if (wicon == 185) { wicon_out = 24; } // # LightSleet
if (wicon == 200) { wicon_out = 42; } // # ThunderyShowers
if (wicon == 227) { wicon_out = 20; } // # LightSnow
if (wicon == 230) { wicon_out = 22; } // # HeavySnow
if (wicon == 260) { wicon_out = 11; } // # Fog
if (wicon == 263) { wicon_out = 40; } // # LightShowers
if (wicon == 266) { wicon_out = 40; } // # LightRain
if (wicon == 281) { wicon_out = 24; } // # LightSleet
if (wicon == 284) { wicon_out = 24; } // # LightSleet
if (wicon == 293) { wicon_out = 40; } // # LightRain
if (wicon == 296) { wicon_out = 40; } // # LightRain
if (wicon == 299) { wicon_out = 18; } // # HeavyShowers
if (wicon == 302) { wicon_out = 18; } // # HeavyRain
if (wicon == 305) { wicon_out = 18; } // # HeavyShowers
if (wicon == 308) { wicon_out = 18; } // # HeavyRain
if (wicon == 311) { wicon_out = 24; } // # LightSleet
if (wicon == 314) { wicon_out = 24; } // # LightSleet
if (wicon == 317) { wicon_out = 24; } // # LightSleet
if (wicon == 320) { wicon_out = 20; } // # LightSnow
if (wicon == 323) { wicon_out = 22; } // # LightSnowShowers
if (wicon == 326) { wicon_out = 22; } // # LightSnowShowers
if (wicon == 329) { wicon_out = 22; } // # HeavySnow
if (wicon == 332) { wicon_out = 22; } // # HeavySnow
if (wicon == 335) { wicon_out = 29; } // # HeavySnowShowers
if (wicon == 338) { wicon_out = 22; } // # HeavySnow
if (wicon == 350) { wicon_out = 24; } // # LightSleet
if (wicon == 353) { wicon_out = 24; } // # LightSleet
if (wicon == 356) { wicon_out = 18; } // # HeavyShowers
if (wicon == 359) { wicon_out = 18; } // # HeavyRain
if (wicon == 362) { wicon_out = 24; } // # LightSleetShowers
if (wicon == 365) { wicon_out = 24; } // # LightSleetShowers
if (wicon == 368) { wicon_out = 22; } // # LightSnowShowers
if (wicon == 371) { wicon_out = 29; } // # HeavySnowShowers
if (wicon == 374) { wicon_out = 24; } // # LightSleetShowers
if (wicon == 377) { wicon_out = 24; } // # LightSleet
if (wicon == 386) { wicon_out = 42; } // # ThunderyShowers
if (wicon == 389) { wicon_out = 42; } // # ThunderyHeavyRain
if (wicon == 392) { wicon_out = 42; } // # ThunderySnowShowers
if (wicon == 395) { wicon_out = 29; } // # HeavySnowShowers
// Create JSON to update nspanel
// Weather Code for weather icon
// Current Temp = current_0["temp_C"]
// Temp range min = weather_0["mintempC"]
// Temp range max = weather_0["maxtempC"]
id(nspanel1).send_json_command(0x81,"{\"HMI_weather\":" + to_string(wicon_out) + ",\"HMI_outdoorTemp\":{\"current\":" + root["current_condition"][0]["temp_C"].as<const char*>() + ",\"range\":\"" +root["weather"][0]["mintempC"].as<const char*>() + "," + root["weather"][0]["maxtempC"].as<const char*>() + "\"}}");
} else {
ESP_LOGD("nspanel_weather", "Current Condition not found");
