Securond
(Securbond)
1
Help to generate in JSON the form
{“devices”: [{“Mac”: “MAC”, “sensors”: [{“ID”:“…”, “value”: 00.00 }, {…} ]}, {…} ]}
to send to the post HTTP requests. The “value” is the id(my_sensor).state
I tried it this way, it doesn’t compile.
> interval:
> - interval: 5min
> then:
> - http_request.post:
> url: http://narodmon.ru/post
> verify_ssl: false
> headers:
> Content-Type: application/x-www-form-urlencoded
> json: |-
> root["devices"] = [
> json: |-
> root["mac"] = "50:64:2B:4D:22:2E";
> root["sensors"] = [;
> json: |-
> root["id"] = "T1";
> root["value"] = id(test_ds).state;
nickrout
(Nick Rout)
2
Doesn’t compile? Yet no error messages are generated? Unbelievable.
Securond
(Securbond)
3
http_request.post:
json: |-
JsonObject &device = root.createNestedArray("devices").createNestedObject();
device["mac"] = "<00:00:00:00:00:00>";
device["name"] = "<Device Name>";
device["owner"] = "<Owners Email>";
device["lat"] = <00.0000>;
device["lon"] = <00.0000>;
JsonArray &sensors = device.createNestedArray("sensors");
JsonObject &temp = sensors.createNestedObject();
temp["id"] = "temperature";
temp["value"] = id(temperature).state;
temp["unit"] = "C";
temp["name"] = "Температура";
JsonObject &co2 = sensors.createNestedObject();
co2["id"] = "co2";
co2["value"] = id(co2ppm).state;
co2["unit"] = "ppm";
co2["name"] = "CO2»;
I don’t know why, but that didn’t work. Perhaps updates changed things?
I found an example on which reads a little easier.
json: |-
root["seg"][0]["on"] = false;
root["seg"][0]["id"] = 0;
root["seg"][1]["on"] = false;
root["seg"][1]["id"] = 1;
root["seg"][2]["on"] = false;
root["seg"][2]["id"] = 2;
root["seg"][3]["on"] = false;
root["seg"][3]["id"] = 3;
lexeyka
5
To date, this does not work. The compiler swears at the lines:
I just removed the & symbol and everything worked. I.e.:
JsonObject device = root.createNestedArray("devices").createNestedObject();
JsonArray sensors = device.createNestedArray("sensors");
JsonObject temp = sensors.createNestedObject();
Блок “interval” тоже немного изменил:
http_request:
timeout: 10s
interval:
- interval: 5min
then:
http_request.post:
url: https://narodmon.com/post
verify_ssl: false
json: |-
Otherwise, everything is unchanged.
