jon1
July 17, 2021, 1:37am
1
I am hoping for help with a project. I have been doing a lot of research and just can’t quite figure it out.
I have a folder of sound files. When my automation is fired, I want it to play a random one.
What I was thinking is:
have home assistant read the files in the folder and save them in an array
pick a random number and use that to select the item in the array
after that, i can handle playing the file and whatever else.
Any help would be much appreciated.
Thanks!
tom_l
July 17, 2021, 1:58am
2
As far as I am aware, Home Assistant cant do point 1 through the services available. You would probably need a Python script for that.
jon1
July 17, 2021, 2:40am
3
I’m thinking there might be a way with the command line sensor? can i just use ‘ls /path/to/folder’ and then feed that sensor data through a template to split the file names into discrete data points and then make an array?
tom_l
July 17, 2021, 2:45am
4
That could work, as long as the result is under the 255 character limit for states.
