If youâre using the NR custom component.
[{"id":"5e66f0fc.b10eb","type":"inject","z":"ffbd7f06.4a014","name":"data received","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"esp8266id\": \"13956060\", \"software_version\": \"BETA-1.0.9.3\", \"sensordatavalues\": [ { \"value_type\": \"SDS_P1\", \"value\": \"3.27\" }, { \"value_type\": \"SDS_P2\", \"value\": \"0.93\" }, { \"value_type\": \"BME280_temperature\", \"value\": \"17.08\" }, { \"value_type\": \"BME280_humidity\", \"value\": \"46.43\" }, { \"value_type\": \"BME280_pressure\", \"value\": \"99248.06\" }, { \"value_type\": \"NH3\", \"value\": \"0.012802\" }, { \"value_type\": \"CO\", \"value\": \"0.234\" }, { \"value_type\": \"NO2\", \"value\": \"0.035237\" }, { \"value_type\": \"NH3-raw\", \"value\": \"605.22\" }, { \"value_type\": \"CO-raw\", \"value\": \"363.54\" }, { \"value_type\": \"NO2-raw\", \"value\": \"34.69\" }, { \"value_type\": \"MICS-calibration-data\", \"value\": \"5625 3034 14384\" }, { \"value_type\": \"Radiation\", \"value\": \"6\" }, { \"value_type\": \"samples\", \"value\": \"280037\" }, { \"value_type\": \"min_micro\", \"value\": \"131\" }, { \"value_type\": \"max_micro\", \"value\": \"1961105\" }, { \"value_type\": \"signal\", \"value\": \"-84\" }, { \"value_type\": \"quality\", \"value\": \"32\" } ] }","payloadType":"json","x":230,"y":1120,"wires":[["ec9c143f.f28da8"]]},{"id":"f30a4628.379848","type":"split","z":"ffbd7f06.4a014","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":383,"y":1120,"wires":[["e3e156ae.5bf828"]],"l":false},{"id":"ec9c143f.f28da8","type":"change","z":"ffbd7f06.4a014","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.sensordatavalues","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":335,"y":1120,"wires":[["f30a4628.379848"]],"l":false},{"id":"e3e156ae.5bf828","type":"switch","z":"ffbd7f06.4a014","name":"","property":"payload.value_type","propertyType":"msg","rules":[{"t":"eq","v":"SDS_P1","vt":"str"},{"t":"eq","v":"SDS_P2","vt":"str"},{"t":"eq","v":"BME280_temperature","vt":"str"},{"t":"eq","v":"BME280_humidity","vt":"str"},{"t":"eq","v":"BME280_pressure","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":466,"y":1120,"wires":[["ffb44edc.3b676"],["fd8ad245.7cc9f"],["f7d1fea9.3c26a"],["83653f12.f8c89"],["7e786e7.9f12b9"]]},{"id":"ffb44edc.3b676","type":"ha-entity","z":"ffbd7f06.4a014","name":"SDS_P1","server":"2dad33ee.42bf5c","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"SDS_P1"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":""}],"state":"payload.value","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":652,"y":1024,"wires":[[]]},{"id":"fd8ad245.7cc9f","type":"ha-entity","z":"ffbd7f06.4a014","name":"SDS_P2","server":"2dad33ee.42bf5c","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"SDS_P2"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":""}],"state":"payload.value","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":652,"y":1072,"wires":[[]]},{"id":"f7d1fea9.3c26a","type":"ha-entity","z":"ffbd7f06.4a014","name":"BME280_temperature","server":"2dad33ee.42bf5c","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"BME280_temperature"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":""}],"state":"payload.value","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":692,"y":1120,"wires":[[]]},{"id":"83653f12.f8c89","type":"ha-entity","z":"ffbd7f06.4a014","name":"BME280_humidity","server":"2dad33ee.42bf5c","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"BME280_humidity"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":""}],"state":"payload.value","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":682,"y":1168,"wires":[[]]},{"id":"7e786e7.9f12b9","type":"ha-entity","z":"ffbd7f06.4a014","name":"BME280_pressure","server":"2dad33ee.42bf5c","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"BME280_pressure"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":""}],"state":"payload.value","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":682,"y":1216,"wires":[[]]}]
