I am running the latest release of Hassio (currently 0.82.1) and over the past week or so I have noticed increased instability and high CPU usage with my install. CPU utilization used to be around 4-6%, but now it is hovering around 29-39%. I have tried stopping various add-ons including the Mosquitto broker and NodeRed, but this doesn’t seem to make a difference.
I’m seeing a high volume of web socket errors and my Dark Sky sensor periodically disappears until I refresh my API key on the Dark Sky dashboard and re-enter it in my config. (I am nowhere near the API daily usage limit). I’m on mobile right now but I can post logs later from a computer if that will help.
I’ve also noticed some “spontaneous” reboots and some instances where components “disappear.” On the Hassio info (i) tab, after a reboot, sometimes the system shows 78 components loaded and other times 83.
Is there any way to monitor which add-on or component is causing the high CPU usage and instability? I was thinking of trying to monitor the different docker containers, but I couldn’t figure out if that is possible on a vanilla install of Hassio. (I do have the SSH add-on installed.)
Thanks in advance for any recommendations.
