I have an Inovelli Black On/Off switch I would like to monitor paddle presses to trigger automations (Toggle smart plug on/off on switch paddle press).
I can’t seem to find any documentation/example on how to monitor for specifc node events and use the data as automation trigger.
I am using the embedded Z-Wave integration in HA (OZW 1.4).
I can see paddle presses in OZW’s node journal:
2020-12-29 17:57:36.439 Info, Node018, Received SwitchBinary report from node 18: level=On
2020-12-29 17:57:36.439 Detail, Node018, Refreshed Value: old value=false, new value=true, type=bool
2020-12-29 17:57:36.439 Detail, Node018, Changes to this value are not verified
2020-12-29 17:57:36.439 Detail, Node018, Notification: ValueChanged
2020-12-29 17:57:37.339 Detail, Node018, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x12, 0x03, 0x25, 0x03, 0x00, 0xc5
2020-12-29 17:57:37.339 Info, Node018, Received SwitchBinary report from node 18: level=Off
2020-12-29 17:57:37.339 Detail, Node018, Refreshed Value: old value=true, new value=false, type=bool
2020-12-29 17:57:37.339 Detail, Node018, Changes to this value are not verified
2020-12-29 17:57:37.339 Detail, Node018, Notification: ValueChanged
2020-12-29 17:57:38.140 Detail, Node018, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x12, 0x03, 0x25, 0x03, 0x00, 0xc5
2020-12-29 17:57:38.140 Info, Node018, Received SwitchBinary report from node 18: level=Off
2020-12-29 17:57:38.140 Detail, Node018, Refreshed Value: old value=false, new value=false, type=bool
2020-12-29 17:57:38.141 Detail, Node018, Changes to this value are not verified
2020-12-29 17:57:38.141 Detail, Node018, Notification: ValueChanged
I just don’t know how to translate this data to be used in automations.
Event monitoring shows nothing when monitoring zwave.node_event
Surely there is a way to fetch these events in HA!
Thanks.
