Help troubleshooting automations
Hey folks,
I just switched from OH2 to Hass.io on Tuesday. This system is great so far. I got everything integrated within 24 hours. I built my first automation that same night. And it worked! Yay! But today I sat down to add 2 new ones and configurator keeps throwing errors. I’ve gone over a bunch of tutorials and examples and everything seems correct. Perhaps a more seasoned set of eyes can spot my error.
Here is my code: (the first one “Smart sleep function” doesn’t break anything by itself)
automation:
# turns off the TV after 3 minutes of the chromecast being idle, after 11 pm
- alias: Smart sleep function
    platform: state
    entity_id: media_player.koalacast_tv
    to: 'off'
    for:
      minutes: 3
  condition:
    condition: time
    after: '23:00'
    before: '05:00'
    service: hdmi_cec.standby
# turns on tv and light at 5:30 am mon-fri if i'm home.
- alias: work wake up
    platform: time
    at: '05:30:00'
  condition: and
  conditions:
    - condition: time
      weekday:
        -mon
        -tue
        -wed
        -thu
        -fri
    - condition: state
      entity_id: 'device_tracker.3096fb3af2ff'
      state: 'home'
    - service: homeassistant.turn_on
      entity_id: light.bedroom
    - service: hdmi_cec.power_on
# turns on light and tv when I get home from work.
- alias: work welcome home
    platform: state
    state: 'home'
  condition:
    condition: time
    after: '15:30:00'
    weekday:
      -mon
      -tue
      -wed
      -thu
      -fri
Here are the errors that it throws:
Testing configuration at /config
ERROR:homeassistant.config:Invalid config for [automation]: expected a dictionary @ data[‘condition’][0]. Got None
extra keys not allowed @ data[‘conditions’]. Got None. (See /config/configuration.yaml, line 89). Please check the docs at https://home-assistant.io/components/automation/
ERROR:homeassistant.config:Invalid config for [automation]: [state] is an invalid option for [automation]. Check: automation->trigger->0->state. (See /config/configuration.yaml, line 89). Please check the docs at https://home-assistant.io/components/automation/
Failed config
automation:
- action: [source /config/configuration.yaml:101]
condition: [source /config/configuration.yaml:97]
after: 23:00
before: 05:00
condition: time
trigger: [source /config/configuration.yaml:91]
platform: state
for: [source /config/configuration.yaml:95]
minutes: 3
to: off
- action: [source /config/configuration.yaml:121]
- entity_id: light.bedroom
alias: work wake up
condition: and
conditions: [source /config/configuration.yaml:110]
- condition: time
weekday: -mon -tue -wed -thu -fri
- condition: state
entity_id: device_tracker.3096fb3af2ff
state: home
trigger: [source /config/configuration.yaml:106]
platform: time
at: 05:30:00
- action: [source /config/configuration.yaml:141]
condition: [source /config/configuration.yaml:132]
after: 15:30:00
condition: time
trigger: [source /config/configuration.yaml:128]
platform: state
state: home
Successful config (partial)
automation:
- action: ?
- service: hdmi_cec.standby
condition: ?
- after: 23:00:00
before: 05:00:00
condition: time
hide_entity: False
trigger: ?
- platform: state
entity_id: ?
- media_player.koalacast_tv
for: 0:03:00
to: off
Any ideas? For reference line 89 is the first note explaining the first automation. Thanks in advance, I’m sure it’s something simple that i’m missing. Cheers folks!
You forgot the opening [condition](https://home-assistant.io/docs/scripts/conditions/): statement.
    platform: time
    at: '05:30:00'
  condition:
    condition: and
    conditions:
      - condition: time
        weekday:
          -mon
          -tue
          -wed
          -thu
          -fri
      - condition: state
        state: 'home'
And then you use an invalid trigger command state, which should be to (in this case).
The error message config:Invalid config for [automation]: [state] is an invalid option for [automation]. in this case flags state as the problem.
    platform: state
    to: 'home'
Thank you so much! Those definitely helped. Another thing that was causing issues was that I forgot to add spaces between the dashes and the weekdays. This was causing errors in the expected dictionary of days.
Thanks again for your help @Tinkerer!
