Ive been on HA Core for over two years. The other day I decided to upgrade from Ubuntu 18.04 to 20.04. I did a clean install and restored my configuration into a python virtual environment. Everything works fine but I have noticed one issue. It seems that after a reboot of the system, the first time HA starts it takes upwards to 3 minutes. I have turned on debugs but I have not been able to find anything meaningful to point me in the direction of what is causing this hang. I thought this was due to HA starting too early in the systemd process, but I moved it to the end and I still see the issue. I even disabled HA in systemd, a manual start of HA after the system has booted still suffers the 3 minute lag. Now for the kicker, subsequent restarts of HA are very quick, 10-15 seconds! Its only after a system reboot do I see this hang. When it occurs these are the messages I see:
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 INFO (MainThread) [homeassistant.components.remote] Setting up remote.apple_tv
Nov 13 07:28:05 hass hass[657]: message repeated 2 times: [ 2020-11-13 07:28:05 INFO (MainThread) [homeassistant.components.remote] Setting up remote.apple_tv]
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 WARNING (MainThread) [homeassistant.components.light] Setup of light platform mqtt is taking over 10 seconds.
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of binary_sensor platform mqtt is taking over 10 seconds.
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform darksky is taking over 10 seconds.
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform tautulli is taking over 10 seconds.
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform mqtt is taking over 10 seconds.
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform command_line is taking over 10 seconds.
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform snmp is taking over 10 seconds.
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform iqvia is taking over 10 seconds.
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform apple_tv is taking over 10 seconds.
Nov 13 07:28:05 hass hass[657]: message repeated 2 times: [ 2020-11-13 07:28:05 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform apple_tv is taking over 10 seconds.]
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform vizio is taking over 10 seconds.
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 INFO (SyncWorker_18) [ciscomobilityexpress.ciscome] _call_api : https://10.7.7.4/data/client-table.html?take=1000
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 INFO (SyncWorker_11) [homeassistant.loader] Loaded sonos from homeassistant.components.sonos
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hacs, device_tracker, mobile_app, nws
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 ERROR (MainThread) [homeassistant.components.media_player] Setup of platform vizio is taking longer than 60 seconds. Startup will proceed without waiting any longer.
Nov 13 07:28:05 hass hass[657]: 2020-11-13 07:28:05 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.1 seconds
At this moment when these messages appear, the HA fronted becomes available. As a troubleshooting step I disabled 90% of my configuration.yaml file, but the problem still persists.
How can I best troubleshoot this issue?
There are several integrations like MQTT that are not configurable via the yaml file, is there a way I can disable the MQTT integration? I suppose you have to delete the integration? just had an ah-ha! moment Perhaps I will take a backup, and disable the integrations and perform a few reboots to test. Sorry for the rambling, it helps to type these things out, more to come…
