mitchell
(Mitchell Stringer)
1
As an example, I have switch in Node-red that says, if payload equal to or greater than 5, do action 1.
I would like to be able to change/set the “5” via home assistant I’m fairly comfortable with NR but don’t know what functions I should be using here.
Bounus separate question.
Is it possible to set the value of a node without triggering the output?
For example, “node 2, 3 and 4” value always equals the same as “node 1”
I think you’re doing it the wrong way. Have a switch in HA trigger a flow in Node-Red
mitchell
(Mitchell Stringer)
3
Thank you but that won’t work in this situation.
I have a flow to automate a portable AC unit, it has a safety switch, so if the exhaust isn’t connected to the vent it won’t turn on.
I have the switch in node red to turn on the AC if the room gets to a certain temperature, and block the flow if the safety becomes disconnected.
Some times I want to set that to a different temperature without editing the flow
JasonRS
(Jason)
4
Could you use input number and read the value in Node Red?
