I want to turn the nest auto_away status into a occupancy sensor but I am having no luck… When home the auto_away state should be off as per the attributes so I want to invert that when making an occupancy sensor.
"away_mode": "off",
"current_temperature": 22.4,
"friendly_name": "Thermostat Main",
"max_temp": 35,
"min_temp": 17.1,
"operation_list": [
"off",
"heat"
"operation_mode": "heat",
"temperature": 21.7,
"unit_of_measurement": "°C"
So I created a binary sensor template, however instead of showing on it always shows off…
sensors:
nest_main_floor_home_away:
value_template: "{% if states.climate.main_floor.away_mode.state == 'off' %}on{% else %}off{% endif %}"
sensor_class: occupancy
