For Z-Wave devices, you have both the A node, which provides all the Z-Wave specific information, and the B node (or nodes) that provides the information for it’s use as a switch/sensor/whatever. For almost all the automation you’ll do you’ll only need the B node, the only time you’re likely to use the A node would be if you wanted to generate notifications (say) when the battery is low.
one clarification: so if I want a notification like: door opened, do I use A node info? or this is only for notification of the device’s hardware itself…
As I said, for almost anything you’ll be using the B node. The A node, starting zwave, only contains Z-Wave (and device) specific information. You’ll really only ever use the A node if you want to be notified of a low battery (for battery powered devices).
The simplest thing to do is to watch the status of all the various nodes for your device while you operate it. For switches, see what happens when you turn it on and off. For sensors, trigger the sensor.
