Help understanding nesting repeat, while, for_next
I have a lengthy non-looping script that I’d like to shorten, if possible.
I am manually:
setting light 1 color
iterating a dropdown with red, white, blue as values
set light 2 color… up to light 5
If it weren’t for iterating that dropdown I’d just use multiple - entityid: entries like this:
- service: light.turn_on
color_name: white
brightness: "250"
transition: 2
entity_id:
- light.bar_light_1
- light.bar_light_2
- light.bar_light_3 .etc.
mode: single
I was trying to nest a for_each in there with
-light.bar_light_1, 2, 3…
But it doesn’t like the way I am trying to nest repeat, for_each in the existing while that checks for the toggle to be on…
Here is what I have. Maybe someone can learn this out so I can add/remove lights easily, instead of copy/pasting a block of code, making it more clumsy and ugly.
Thanks in advance.
patriotic_lamp_posts_running:
sequence:
- repeat:
while:
- condition: state
entity_id: input_boolean.patriotic_lamp_posts
state: "on"
sequence:
entity_id: light.lamp_post_1
color_name: "{{ states('input_select.patriotic_colors_2') }}"
transition: 1.0
- service: input_select.select_next
entity_id: input_select.patriotic_colors_2
entity_id: light.lamp_post_2
transition: 1.0
entity_id: light.lamp_post_3
transition: 1.0
entity_id: light.lamp_post_4
transition: 1.0
entity_id: light.lamp_post_5
transition: 1.0
- delay: "00:00:05"
I am answering my own question: (I have 3 ‘bar lights’ and 5 ‘lamp post lights’ in two diff toggles)
patriotic_lamp_posts_on:
  alias: Patriotic Lamp Posts on
  sequence:
    - service: scene.create
        scene_id: patrioticlampposts
        snapshot_entities:
          - light.lamp_post_1
          - light.lamp_post_2
          - light.lamp_post_3
          - light.lamp_post_4
          - light.lamp_post_5
    - service: script.turn_on
      entity_id: script.patriotic_lamp_posts_running
  sequence:
    - repeat:
        while:
          - condition: state
            state: "on"
        sequence:
            entity_id: script.patriotic_lamp_posts_switcher
          - delay: "00:00:05"
patriotic_lamp_posts_switcher:
  sequence:
    - repeat:
        for_each:
          - "light.lamp_post_1"
          - "light.lamp_post_2"
          - "light.lamp_post_3"
          - "light.lamp_post_4"
          - "light.lamp_post_5"
        sequence:
              entity_id: "{{ repeat.item }}"
              transition: 1.0
patriotic_bar_lights_on:
  alias: Patriotic Bar Lights on
  sequence:
        scene_id: patrioticbarlights
        snapshot_entities:
          - light.bar_light_1
          - light.bar_light_2
          - light.bar_light_3
      entity_id: script.patriotic_bar_lights_running
patriotic_bar_lights_running:
  sequence:
    - repeat:
        while:
          - condition: state
            entity_id: input_boolean.patriotic_bar_lights
            state: "on"
        sequence:
            entity_id: script.patriotic_bar_lights_switcher
          - delay: "00:00:10"
patriotic_bar_lights_switcher:
  sequence:
      entity_id: input_select.patrioticcolors
    - repeat:
        for_each:
          - "light.bar_light_1"
          - "light.bar_light_2"
          - "light.bar_light_3"
        sequence:
              color_name: "{{ states('input_select.patrioticcolors') }}"
              transition: 1.0
