Hi
I’m looking to update the firmware for a Zigbee device but struggling. I’m running 2023.9.3 and using the Sonoff USB 3 Dongle Plus.
Here’s what I’ve tried.
In configuration.yaml :
zha:
zigpy_config:
ota:
thirdreality_provider: true
Then this:
service: zha.issue_zigbee_cluster_command
ieee: <the device IEEE>
endpoint_id: 1
cluster_id: 25
cluster_type: out
command: 0
command_type: client
params:
payload_type: 0
query_jitter: 100
And this:
Manage zigbee device >>
select OTA cluster (id: 0x0019) >>
click commands >> select image_notify (id: 0x0000) >>
mark payload_type: QueryJitter >>
move the query_jitter slider so its not being at default zero >>
ignore manufacturer_code/ image_type/ new_file_version fields >>
"Issue Zigbee command" button.
All this and nothing happens. Then, I even got a hold of the actual .ota firmware file, placed it in the config/zigpy_ota folder and edited the configuration.yaml code below, then restarted.
zha:
zigpy_config:
ota:
otau_directory: /config/zigpy_ota
Still nothing happens - when I check the firmware version (app_version (id: 0x0001)) it’s unchanged.
Any ideas what I’m doing wrong?
