Friends, I am a real newbie here but am just trying to have a minor success in changing my direcTV channel from HA. I am running hassio 0.61 on a pi3. Here is my configuration.yaml:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: !secret sec_latitude
longitude: !secret sec_longitude
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 90
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/Chicago
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Secrets are defined in the file secrets.yaml
api_password: !secret http_password
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# Example configuration.yaml entry for the HTTP component
# ssl_certificate: fullchain.pem
# ssl_key: privkey.pem
# Checks for available updates
#Note: This component will send some information about your system to
#the developers to assist with development of Home Assistant.
#For more information, please see:
#https://home-assistant.io/blog/2016/10/25/explaining-the- updater/
updater:
#Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
#Discover some devices automatically
discovery:
#Allows you to issue voice commands from the frontend in enabled browsers
conversation:
#Enables support for tracking state changes over time
history:
#View all events in a logbook
logbook:
#Enables a map showing the location of tracked devices
map:
#Track the sun
sun:
#Weather prediction
- platform: yr
#Text to speech
tts:
- platform: google
#Cloud
cloud:
media_player:
- platform: directv
host: 192.168.1.113
port: 8080
name: Main DirecTV Box
device: 0
- platform: directv
host: 192.168.1.113
port: 8080
device: 403DECCE6596
input_number:
box1:
initial: 2
min: 0
max: 1000
step: 1
mode: box
climate:
- platform: honeywell
username: !secret hon_username
password: !secret hon_password
scan_interval: 600
region: us
##...snipped out TV section as it is very long...
shell_command:
dtv_channel: 'curl -X GET http://192.168.1.113:8080/tv/tune?major={{channel}}&minor=65535&clientAddr=403DECCE6596'
group: !include groups.yaml
script: !include scripts.yaml
My automation file:
- alias: directv_change_channel
- entity_id: input_number.box1
platform: state
- service: shell_command.dtv_channel
#channel: '202' ***This one worked**
#channel: 'input_number.box1.channel'
#channel: 'input_number.box1.state'
#channel: '{{ states(input_number.box1) }}'
#channel: 'channel'
#channel: input_number.box1
channel: "{{ states.input_number.box1.state }}"
#data_template:
#channel: '206' ***This one worked***
#channel: '{{ states.input_number.box1.state }}'
#channel: '{{ state(input_number.box1) }}'
condition: []
Everything seems to work fine when I hard code the channel. However, you can see everything I have tried to get the variable channel to be set to the value of the input_number. I am really trying to learn here, what troubleshooting steps should I be taking? In other environments, I would view the value of the variable as I am calling the function, but I haven’t figured out how to do that here.
(edit: I also have know idea why the formatting of my message is dorked up)
(edit: I have edited to use preformatted text but it did not help much. Ok finally got it looking better…)
montyhp
