I would like to use the generated JSON link at Visual Crossing personal area with the RESTful integration, but I can’t figure out with the documentation at RESTful - Home Assistant.
I tried adding some entries in configuration.yaml, but weather data then looks empty so it looks like I did not enter what needed…
what do you want to get out of this? ‘some entries’ is vague.
Hmm good question, but I suppose all the entries I opted to choose in my personal area where we generate then the JSON link.
There are tons of entries…you need to be more exact as to what you want to achieve, single values, graphs, etc.
And do note that the link you sent contains lat/lon so if this represents your home, then suggest to remove it.
Yeah my bad I could just name the website lol.
I thought adding everything wasn’t a nightmare so I see if I can lower the amount of details.
May I PM you the new link then and hope for some help?
yep…just think about what you want to do with the data…loading things needs a purpose
Do you want to automate, only create grpahs (which one/purpose) or track changes over time, each can result in a different entity
