My first time asking a question in this community, I tried to search how to do it before posting but no luck
So here is the situation, I want home assistant to trigger a Assistant Routine(google home) to announce a particular value based on current sensor value, I want the assistant relay to announce “time to full”, sensor.water_level gets a int number every 7 seconds, thats the current level of water and here is the formula Im using to calculate ETA to full for the 1070 Liters of tank inside the template
{{states('sensor.water_level')| int * -1/23.1 + 1070/23.1 }}
Value I am getting if the water level is 840 Liters is 9.956709956709958
which is very accurate… too accurate… it takes the google assistant a while to announce all the decimals, is there any way I can convert this into minutes? or even a int would be fine…
( I have used the above formula inside a rest command for assistant relay and it works fine)
service: rest_command.assistant_relay
command: >-
announce on kitchen speaker, {{states('sensor.water_level')| int * -1/23.1 + 1070/23.1 }} minutes
