Hi everyone. I have an Unexpected Maker FeatherS2 (board: um_feathers2
) that according to the pinout diagram, has an APA102 2020 RGB LED using pin 40 for data and pin 45 for the clock. It works fine with MicroPython, but for ESPHome, it refuses to compile if I define the LED like so:
light:
- platform: fastled_spi
chipset: APA102
data_pin: GPIO40
clock_pin: GPIO45
num_leds: 1
# rgb_order: BRG
It fails to compile with the error:
.piolibdeps/feathers2/FastLED/fastpin.h:207:24: error: static assertion failed: Invalid pin specified
There are a couple of warnings on the ESPHome FastLED docs, but I don’t think either apply. This is an ESP32, not an ESP8266, and I don’t think it’s using ESP-IDF to compile.
Any ideas on how I can get this to work?
For context: I’m using the ESPHome docker image on an x86-64 Unraid Linux server.
Also, for anyone else trying to use the feathers2 board, it’s a bit of a doosey to get the initial setup working. I was unable to flash it in the browser through either my ESPHome dashboard or web.esphome.io. esptool.py
also failed when I used the version installed via apt-get, complaining about OSError: [Errno 71] Protocol error
initially, and then A fatal error occurred: Failed to enter Flash download mode (result was 01050000)
when I specified more flags.
But, I was finally able to get it to work by downloading the latest esptool release from github and running these commands (based on the instructions for reinstalling MicroPython):
esptool --chip esp32s2 --port /dev/ttyACM0 erase_flash
esptool --chip esp32s2 --port /dev/ttyACM0 write_flash 0x0 '/home/nfriedly/Downloads/feathers2-factory.bin'
(Where feathers2-factory.bin
is the file I got after choosing Install > Manual Download > Modern format in the ESPHome dashboard.)
