I need some help please with a binary position sensor (reed switch) for a gate relay.
I have a Shelley Plus 1 that has been flashed to Tasmota.
I have configured the device and can see the sensor status (open/closed) in the console of the device, this works as planned.
I can see the device and sensor including the correct state in MQTT Explorer and all work as planned
I have installed the Tasmota integration in HA and the device is visible
Unfortunately this is where I have the issue
I can toggle the device to activate the gate as planned
However the sensor is NOT visible and I cannot see the open or closed state of the gate
The entities that I can see are
Last restart time
MQTT connection count
Restart reason
SSID
WiFi connection count
The following are are hidden but still accessible
Firmware version
IP
RSSI
Signal (WiFi signal strength)
I believe I will need to create a template but I cannot find the sensor in the list of entities to reference.
Any help will be greatly appreciated
