Hi, I’d like to setup a Sonoff ZBMINIL2 for my light switch. Sadly I’m not familiar enough with wiring switches, so I’d like some help with it.
It’s a classic ON/OFF switch, with ON when pressed on the top side. The same light bulb is connected to another switch. Looking at the following photo, how should I connect the wires to the Sonoff? Thanks.
Let’s make it simpler, I want to ignore the existence of the second wall switch. So the setup is the switch in the photo and the Sonoff.
How would I wire it?
From that photo and description nobody can answer.
First make sure the existing switch is switching L (sometimes you find switches on N).
Find the wire that is coming from breaker (always hot) an find the wire that is going to light.
I expect your wiring being like this:
