I am trying to mount a small project, in theory very simple, but something is wrong and I am getting crazy. I hope you can help me to understand what is wrong.
I have an ESP8266 and 2 flow sensors.
The flow sensors are like this (ignore the picture in the scheme)
And my the definition of the sensors is like this:
- platform: pulse_counter
pin: GPIO5
name: "Flujo agua (1)"
update_interval: 10s # 60s is default value
unit_of_measurement: 'L/min'
filters:
- lambda: return (x / 486.0); # Pulso de flujo: F (Hz) = 8,1 * Q – 3 (+/- 10%) Q = L / min -> # 486 = 8,1 * 60
pin: GPIO4
name: "Flujo agua (2)"
filters:
If I disconnect GPIO4 wire: I can read the flow in “Flujo agua (1)” (comming from GPIO5). The other sensor reads 0.
If I disconnect GPIO5 wire: I can read the flow in “Flujo agua (2)” (comming from GPIO4). The other sensor reads 0.
BUT if I connect both pins at the same time. When water is flowing for 1 sensor, I get the same value in both of them. If for example I get water flowing throw sensor in GPIO5, I get the value read in “Flujo agua (1)” but also in “Flujo agua (2)”…Same result the other way.
I am not sure, but could it be that the “x” variable is global in the code, so is always the same for both sensors?
What happens when you temporarily take out the filters: are the returned values still the same for both?
Thanks Tom,
It seemed to be a logical explanation for this problem. Are you talking from own experience?
I have been searching the documentation and the code on GitHub for this, but have not been successful.
Do you know where this is specified?
To test it I modified the code of one of my ESP devices like this:
# DS18B20 Temperatuur sensors
- platform: dallas
dallas_id: dallas_hub_1
address: 0x2206201221529C28
name: $friendly_name Warmtepomp Uitgaande lucht Temperatuur
filters:
# - offset: 0.3
- lambda: return x + 0.3;
- platform: dallas
address: 0x9F00000D31EF4928
name: $friendly_name Warmtepomp Sensor behuizing Temperatuur
filters:
# - offset: 0.3
This are two identical DS18B20 sensors, but in a different environment.
If the “x” variable would not be local to each sensor the values should be the same now, and they are not.
So (at least with DS18B20 dallas sensors) it looks like the “x” variable indeed is local to each sensor.
Could it still be that this is a specific issue with two pulse counters?
I have been doing some tests with your suggestions.
Separate the grounds (You have 4 GND pins)? → No, I don’t
Try another power supply? → Same result
Have you soldered to the NodeMCU ? → No
pull-up or pull-down resistance → pull-up:no changes, pull-down: compile error, only available for GPIO16
What happens when you temporarily take out the filters: same “bug”
Try using different GPIO pins? → This was my first attempt, changing one of the pins (changing GPIO4 by another one), with no result, but now I have tried again, changing both of them and it looks like it’s working fine now.
I did a couple of changes:
Change board definition setting “nodemcuv2” (I had esp01_1m)
Change GPIO4 & GPIO5 with D3 & D4
I guess that the issue is happening when I use the GPIO5 (D1) pin.
Anyway, it looks like now is working fine so, thank you very much.
