Help with a cam display automation
I have a nest cam at my front door, down the path I have a motion sensor, when the front path motion sensor is triggered it takes around 10 seconds to reach the front door. I have set up an automation to display that camara on a Google hub in the living room, here’s the problem.
I am not getting a live stream, the display doesn’t give me the camera live or even a few seconds delay, it gives me the last 15 seconds or so, I would expect to see the person at the door or, at least, approaching. What I actually get is an empty path, then you see the person entering the gateway and coming up the path.
Is this a nest issue or my automation.
alias: Activity at front door
description: ""
  - type: motion
    platform: device
    device_id: e40521b4c47205345728badacxxxxxxx
    entity_id: 855949765a3fdfe4148ca97d0bxxxxxxx
    domain: binary_sensor
  - type: no_motion
    platform: device
    device_id: e40521b4c47205345728badac9xxxxxx
    for:
      hours: 0
      minutes: 1
      seconds: 0
condition:
  - condition: time
    after: "07:00:00"
    before: "23:00:00"
    weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
      - sat
      - sun
  - choose:
      - conditions:
          - condition: trigger
            id:
              - cam-needed
        sequence:
          - action: camera.play_stream
            metadata: {}
              format: hls
              media_player: media_player.living_room_display
              device_id: 3d119382868da9813d889a0b2xxxxx
      - conditions:
            id:
              - cam-not-needed
        sequence:
          - action: media_player.turn_off
            metadata: {}
            data: {}
              device_id: c9e460efea693bf3d4fb592517xxxxx
mode: single
Thanks in advance …
Any ideas?
