Help with a floor plan dashboard
Hi everyone.
I’ve spent the last 5 hours following a tutorial on how to get a floor plan in to HA and I am stuck.
This is the tutorial I have followed but he goes sooooo fast and there are some assumptions I know things that I clearly do not. Interactive 3D floor plan with colour syncing lights using SweetHome 3D - YouTube
  • I uploaded all the images of the plans into the media section on the left navigation bar.
  • Then I created a folder in config named ‘www’.
  • I then added the image files in the ‘www’ folder which were the filepaths for the images which are saved in the media section. These can be seen in the attached screengrab labelled ‘folders and files’
  • In the code the image paths are “image: /config/www/local/images/GFNight.png” etc
As far as I can tell, there is nothing else to do to get the floor plan into Home Assistant but it’s just not working and I don’t know why.
Any help is greatly appreciated.
This is the code I have put into a folder called floorplan within config
title: Floorplan
icon: mdi:floor-plan
path: Floorplan
panel: true
cards:
  - type: "custom:config-template-card"
    entities:
      - switch.3g_wifi_switch_wifi_ble_switch_1
      - switch.3g_wifi_switch_wifi_ble_switch_2
      - switch.3g_wifi_switch_wifi_ble_switch_3
      - switch.cabinet_lights_switch_1
      - light.utility
      - light.sonoff_a48004c80f
      - switch.hall_switch_1
      - switch.downstairs_toilet
    card:
        type: picture-elements
        style: |
          ha-card:first-child {
            background: rgba(42, 46, 48, 1)
        elements:
          - type: image
            action: none
            entity: sun.sun
            state_image:
            above_horizon: /local:8123/media/local/GFFirst.png
            below_horizon: /config/www/local/images/transparent.png
            style:
            height: 100%
            left: 50%
            mix-blend-mode: lighten
            opacity: '${ states[''sensor.sunlight_opacity''].state }'
            top: 50%
            width: 100%
            tap_action:
                action: none
            hold_action:
                action: none
          - type: image
            action: none
            entity: switch.3g_wifi_switch_wifi_ble_switch_1
            hold_action:
                action: none
                image: /config/www/local/images/GFKitchenSpotsON.png
            style:
            filter: >-
              ${ "hue-rotate(" + (states['light.sitting_left_orb'].attributes.hs_color
              ? states['light.sitting_left_orb'].attributes.hs_color[0] : 0) + "deg)"}
            left: 50%
            opacity: "${states['light.sitting_left_orb'].state === 'on' ? (states['light.sitting_left_orb'].attributes.brightness / 255) : '0'}"
            top: 50%
            width: 100%
            height: 100%
            tap_action:
                action: none
          - type: image
            action: none
            entity: switch.3g_wifi_switch_wifi_ble_switch_2
            hold_action:
                action: none
                image: /config/www/local/images/GFDiningON.png
            style:
            filter: >-
            left: 50%
            top: 50%
            width: 100%
            height: 100%
            tap_action:
                action: none
          - type: image
            action: none
            entity: switch.3g_wifi_switch_wifi_ble_switch_3
            hold_action:
                action: none
                image: /config/www/local/images/GFKitchen1ON.png
            style:
            filter: >-
            left: 50%
            top: 50%
            width: 100%
            height: 100%
            tap_action:
                action: none
          - type: image
            action: none
            entity: switch.cabinet_lights_switch_1
            hold_action:
                action: none
                image: /config/www/local/images/GFCabinetON.png
            style:
            filter: >-
            left: 50%
            top: 50%
            width: 100%
            height: 100%
            tap_action:
                action: none
          - type: image
            action: none
            entity: light.utility
            hold_action:
                action: none
                image: /config/www/local/images/GFUtilityON.png
            style:
            filter: >-
              ${ "hue-rotate(" + (states['light.bedroom_light'].attributes.hs_color
              ? states['light.bedroom_light'].attributes.hs_color[0] : 0) + "deg)"}
            left: 50%
            opacity: "${states['light.bedroom_light'].state === 'on' ? (states['light.bedroom_light'].attributes.brightness / 255) : '0'}"
            top: 50%
            width: 100%
            height: 100%
            tap_action:
                action: none
          - type: image
            action: none
            entity: light.sonoff_a48004c80f
            hold_action:
                action: none
                image: /config/www/local/images/GFLoungeON.png
            style:
            filter: >-
              ${ "hue-rotate(" + (states['light.bedside_right'].attributes.hs_color
              ? states['light.bedside_right'].attributes.hs_color[0] : 0) + "deg)"}
            left: 50%
            opacity: "${states['light.bedside_right'].state === 'on' ? (states['light.bedside_right'].attributes.brightness / 255) : '0'}"
            top: 50%
            width: 100%
            height: 100%
            tap_action:
                action: none
          - type: image
            action: none
            entity: switch.hall_switch_1
            hold_action:
                action: none
                image: /config/www/local/images/GFHallON.png
            style:
            filter: >-
              ${ "hue-rotate(" + (states['light.sitting_room_main'].attributes.hs_color
              ? states['light.sitting_room_main'].attributes.hs_color[0] : 0) + "deg)"}
            left: 50%
            opacity: "${states['light.sitting_room_main'].state === 'on' ? (states['light.sitting_room_main'].attributes.brightness / 255) : '0'}"
            top: 50%
            width: 100%
            height: 100%
            tap_action:
                action: none
          - type: image
            action: none
            entity: switch.downstairs_toilet
            hold_action:
                action: none
                image: /config/www/local/images/GFWCON.png
            style:
            filter: >-
              ${ "hue-rotate(" + (states['light.counter_led'].attributes.hs_color
              ? states['light.counter_led'].attributes.hs_color[0] : 0) + "deg)"}
            left: 50%
            opacity: "${states['light.counter_led'].state === 'on' ? (states['light.counter_led'].attributes.brightness / 255) : '0'}"
            top: 50%
            width: 100%
            height: 100%
            tap_action:
                action: none
It’s a long time since I did my own floorplans, so things may have changed, but as I remember “local” maps onto “config/www” - you have both in your path. So the image is (for example) config/www/ground_floor5.png but the path in the dashboard is /local/ground_floor5.png.
