Hi, new to HA and with a little-to zero knowledge of coding
I have installed a wifi switch for my awning.
I can see at services that there is a service
=cover.set_cover_position
and I get the following in developres tool
You need to post any code / entity configuration using the </> button above the edit box
spacing is important and normal paste destroys it
If I were you I’d create an input_number (look it up) to store desired position
I’d then create an automation triggered by a change in the above number to fire an action
the action I’d fire would be (i’m guessing here)
- service: cover.set_cover_position
entity_id: cover.50758014840d8e918614 ### who names these dang things and why havn't you changed it ???
data_template:
position: "{{ states('input_number.my_awning_position' | int }}"
But I’m not 100% sure, put it through your check config and comeback if it complains
I don’t understand what you mean to
“to post any code / entity configuration using the </> button above the edit box”
can you please elaborate?
I read about input number and I can understand what I could do
However, I would like (somehow) to check first that my switch does support the service
Is there away to physical check it?
When you click reply …
A little box opens up for you to type text into …
In the header of “the box” … (not the whole popup) …
is a row of buttons to quote, embolden, italiscise …
The 7th one in … is … </> …
Check Service …
Go to “Developer Tools”
Click Services …
Select the service you want to test …
Select the entity you want to test this on …
Call the service …
I’m not sure, I don’t have an awning.
I do have dimmers and though I can use this to turn them on and off, I have not been able to set a level, so perhaps this is a bit limited.
Is the awning the only device you have?
Try something else.
I must admit in nearly 3 years of HA I’ve never used this feature til today.
I’d just write the automation and try it.
Maybe someone else can help
