Help with a template to count all the lights on
Hello Everyone,
Thank you in advance to everyone who keeps on helping others here.
Currently, i have two types of templates:
Template-1: (This counts all the lights that are in on state in my home)
  sensors:
    lights_on_counter:
      friendly_name: Lights on counter
      value_template: >-
        {{ states.light
              |rejectattr('attributes.entity_id', 'defined')
              |selectattr('state', 'eq', 'on')
              |list
              |count
      icon_template: mdi:lightbulb-group
Template-2: (This counts only the lights inside the template)
  - sensor:
      - name: "lights on"
        unique_id: lights_on
        icon: mdi:lightbulb-on
        state: >
          {% set lights = [
              states('light.office_1'),
              states('light.office_2'),
              states('light.office_3'),
              states('light.office_4'),
          {{ lights | select('eq', 'on') | list | count }}
Can someone please help me create a template where I can get a number for all the lights that are ‘on’ but exclude a few light entities?
Moved. Please read the topic descriptions. This is not a community guide.
template:
  - sensor:
      - name: Lights on counter
        state: >-
          {% set exclusions = ['light.office_1', 'light.office_2', 'light.office_3'] %}
          {{ states.light
            | rejectattr('entity_id', 'in', exclusions)
            | selectattr('state', 'eq', 'on') | list | count }}
        icon: mdi:lightbulb-group
Thank you so much, this worked perfectly
Thanks for this, super helpful. Is there a way to use wildcards in the exclusion list e.g light.ld2410_*
{{ states.light
  | rejectattr('object_id', 'search', 'ld2410_*')
  | list | count }}
Wow, that’s awesome. Thank you so much.
It seems there is a limit to the reject list? This works
{{ states.light
  | rejectattr('object_id', 'search', 'ld2410_*', 'wled_notifier_*')
  | list | count }}
But this does not citing `TypeError: regex_search() takes from 1 to 3 positional arguments but 4 were given`
{{ states.light
  | rejectattr('object_id', 'search', 'ld2410_*', 'wled_notifier_*', 'tab8_ultra_screen')
  | list | count }}
I suggest you review this section of the documentation.
You can’t simply tack on additional arguments to the search function; that’s not how it works.
It accepts one regex pattern. Regex is a powerful pattern-matching language.
rejectattr('object_id', 'search', '(ld2410_*|wled_notifier_*|tab8_ultra_screen)')
I managed to do it using labels.
type: custom:mushroom-template-card
icon: >-
  {% if states("sensor.light_counter") | int > 0 %}mdi:lightbulb-on-outline{%
  else %}mdi:lightbulb-outline{% endif %}
icon_color: >-
  {% if states("sensor.light_counter") | int > 0 %}yellow{% else %}grey{% endif
primary: Lights On
secondary: |-
  {{ states.light
  | rejectattr('entity_id', 'in', label_entities('Group'))
  | rejectattr('entity_id', 'in', label_entities('Dummylight'))
  | list
  | count }}
