I’m creating a custom card for my AC unit, which is connected to a Zigbee smart plug.
I need help with the secondary information display. It should show:
- Power consumption in Watts
- Runtime (when on) or time since last use (when off)
- Considers >10W as “on” and ≤10W as “off” due to occasional smart plug update issues
The problem is that the time display resets with every power consumption update, rather than showing the cumulative time since the last state change (on/off). I want:
- When on: Display time elapsed since power exceeded 10W
- When off: Display time elapsed since power dropped below 10W
I assume my current attempt is massively overcomplicated. How can I fix this issue?
Here is the YAML code I have so far:
entity: sensor.zigbee_plug_ac_power
icon: |
{% if states('sensor.zigbee_plug_ac_power')|float > 10 %}
mdi:fan
{% else %}
mdi:fan-off
{% endif %}
icon_color: |
green
{% else %}
gray
{% endif %}
primary: Air Conditioner
secondary: >
{% set power = states('sensor.zigbee_plug_ac_power')|float %} {% set
current_time = now().timestamp() | int %} {% if power > 10 %}
{% if not state_attr('sensor.zigbee_plug_ac_power', 'last_active') %}
{% set start_time = current_time | int(0) %}
{% else %}
{% set start_time = state_attr('sensor.zigbee_plug_ac_power', 'last_active') | int(0) %}
{% endif %}
{% else %}
{% set start_time = states.sensor.zigbee_plug_ac_power.last_changed.timestamp() | int %}
{% endif %} {% set time_diff = current_time - start_time %} {% set minutes
= (time_diff / 60) | int %} {% set hours = (minutes / 60) | int %} {% set
remaining_minutes = minutes % 60 %} {% if power > 10 %}
Active: {{ power|round(1) }} W (Since {% if hours > 0 %}{{ hours }}h {% endif %}{{ remaining_minutes }}m)
{% else %}
Turned Off (Since {% if hours > 0 %}{{ hours }}h {% endif %}{{ remaining_minutes }}m ago)
{% endif %}
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style:
mushroom-shape-icon$: |
.shape {
--shape-animation: spin 1s linear infinite;
{% else %}
--shape-animation: none;
{% endif %}
display: flex;
.shape::before {
animation: var(--shape-animation);
@keyframes spin {
from {
transform: rotate(0deg);
to {
transform: rotate(360deg);
state_display: |
states('sensor.zigbee_plug_ac_power') | float > 10
and states('sensor.zigbee_plug_ac_power')
or 'Off'
extra_attributes:
last_active: |
{% if states('sensor.zigbee_plug_ac_power') | float > 10 %}
{{ now().timestamp() | int }}
{% else %}
{{ state_attr('sensor.zigbee_plug_ac_power', 'last_active') }}
{% endif %}
