Using HA 0.106.6 and the latest play store release of the companion app, and I’m trying to get actionable notifications working however I’m clearly not grasping the methods explained in other threads in this section of the forums.
I’m looking to be able to click on the app notification and be taken to a live view of the relevant camera.
Currently I have all my cameras represented in one tab / view on the lovelace dashboard using picture-entity cards.
Can someone clarify for me:
Do I need to setup a separate tab / view per camera for what I have in mind? If so, can this be hidden from the main dashboard?
I understood that I needed to provide the path to the notification as “/lovelace/” however when I try calling the service pointing at my current cameras view with:
Unfortunately clickAction does not open the specified relative path in the app merely the default view, although it looks on github as though that specific issue was raised and Fixed.
Thanks. I found that link a new minutes ago, and gave it a try. It does work, but I’m not really satisfied with the result. It’s slow. It takes a while for the companion app to load, then it redirects… Too slow for a camera or a video doorbell. Even if it was faster, there is still no 2 way audio. I’m sticking with opening the Reolink app instead, at least until 2 way audio support in HA gets implemented
