Help with activating themes
I’m trying to change the default theme of Home Assistant and i’m following the instructions like JuanmTech has on his website.“https://www.juanmtech.com/themes-in-home-assistant/
But. I can’t get them activated in my profile section.
The configuration file is wrong by checking the configuration file:
" Configuration invalid
Component error: themes - Integration themes not found."
My configuration file contains the following:
# Configure a default setup of Home Assistant (frontend, api, etc)
frontend:
themes: !include theme.yaml
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
What am I doing wrong? I’ve searched everything about googleand the forums and no clearly solution I can find.
Bad indentation. Try:
frontend:
Hi Folks,
Sorry for the basic question, but I stuck.
What is a mistake I made with the theme integration in configuration.yaml?
I receive an error message when configuration is checked: “Component error: theme - Integration ‘theme’ not found”
I didn’t find solution even I’ve searching for hours
default_config:
# Text to speech
tts:
homeassistant:
  customize: !include customize.yaml
scene: !include scenes.yaml
sensor: !include sensors.yaml
theme: !include themes.yaml
this thread already has your answer, see tom’s reply and check it against your configuration.
Thanks, I’ve tried again and now it works. Previously I’ve tried it in a same way, I think, but a mistake might made.
Now it works! Thank you!
Solution:
homeassistant:
frontend:
  themes: !include themes.yaml
