Hi everyone!
I am still a beginner with Home Assistant.
I started to use themes after following some tutorials.
I would like to change the color of all the buttons when they are active.
But I fail with finding which setting to alter to do so.
I’m using Google Light and Dark theme in dark mode.
Here is the picture of the color element I want to change.
The code for the google.yaml file is as follow:
dark:
# Header:
app-header-background-color: rgb(23, 23, 23)
app-header-text-color: rgb(198, 203, 210)
# Main Interface Colors
primary-color: rgb(138, 180, 248)
light-primary-color: var(--primary-color)
primary-background-color: rgb(23, 23, 23)
secondary-background-color: rgb(32, 33, 36)
divider-color: var(--primary-background-color)
accent-color: rgb(138, 180, 248)
# Text
primary-text-color: rgb(242, 242, 242)
secondary-text-color: rgb(166, 166, 166)
text-primary-color: var(--primary-text-color)
disabled-text-color: rgba(184, 190, 199, 0.4)
# Sidebar Menu
sidebar-icon-color: rgb(169, 177, 188)
sidebar-text-color: rgb(198, 203, 210)
sidebar-background-color: rgb(32, 33, 36)
sidebar-selected-background-color: var(--primary-background-color)
sidebar-selected-icon-color: rgb(138, 180, 248)
sidebar-selected-text-color: var(--sidebar-selected-icon-color)
# Buttons
paper-item-icon-color: rgb(169, 177, 188)
paper-item-icon-active-color: rgb(0, 180, 0)
# States and Badges
state-icon-color: rgb(111, 111, 111)
state-icon-active-color: rgb(0, 180, 0)
state-icon-unavailable-color: var(--disabled-text-color)
# Sliders
paper-slider-knob-color: rgb(138, 180, 248)
paper-slider-knob-start-color: var(--paper-slider-knob-color)
paper-slider-pin-color: var(--paper-slider-knob-color)
paper-slider-active-color: var(--paper-slider-knob-color)
paper-slider-secondary-color: var(--light-primary-color)
# Labels
label-badge-background-color: rgb(32, 33, 36)
label-badge-text-color: rgb(198, 203, 210)
label-badge-red: rgb(208, 101, 104)
label-badge-green: rgb(128, 200, 132)
label-badge-blue: rgb(138, 180, 248)
label-badge-yellow: rgb(223, 194, 113)
label-badge-gray: rgb(95, 98, 103)
# Cards
card-background-color: rgb(32, 33, 36)
ha-card-border-color: none
ha-card-border-width: 0px
paper-dialog-background-color: var(--card-background-color)
paper-listbox-background-color: var(--card-background-color)
paper-card-background-color: var(--card-background-color)
# Switches
switch-checked-button-color: rgb(0, 180, 0)
switch-checked-track-color: rgb(0, 180, 0)
switch-unchecked-button-color: rgb(172, 176, 185)
switch-unchecked-track-color: rgb(154, 160, 166)
# Toggles
paper-toggle-button-checked-button-color: var(--switch-checked-button-color)
paper-toggle-button-checked-bar-color: var(--switch-checked-track-color)
paper-toggle-button-unchecked-button-color: var(--switch-unchecked-button-color)
paper-toggle-button-unchecked-bar-color: var(--switch-unchecked-track-color)
# Table
table-row-background-color: var(--primary-background-color)
table-row-alternative-background-color: var(--secondary-background-color)
data-table-background-color: var(--primary-background-color)
mdc-checkbox-unchecked-color: rgb(169, 177, 188)
# Dropdowns
material-background-color: var(--secondary-background-color)
material-secondary-background-color: var(--primary-background-color)
mdc-theme-surface: var(--primary-background-color)
# Pre/Code
markdown-code-background-color: rgb(23, 23, 23)
# Checkboxes
mdc-select-fill-color: rgb(32, 33, 36)
mdc-select-ink-color: var(--primary-text-color)
mdc-select-label-ink-color: var(--secondary-text-color)
mdc-select-idle-line-color: var(--primary-text-color)
mdc-select-dropdown-icon-color: var(--secondary-text-color)
mdc-select-hover-line-color: var(--accent-color)
# Input
input-fill-color: var(--secondary-background-color)
input-dropdown-icon-color: var(--secondary-text-color)
input-ink-color: var(--primary-text-color)
input-label-ink-color: var(--secondary-text-color)
input-idle-line-color: var(--primary-text-color)
input-hover-line-color: var(--accent-color)
Does anyone have any idea?
