I have a small problem that I don’t know how to deal with. Need your help.
It seems that I have deleted binary_sensor.updater entity days ago and right now realised that it could be useful. I cannot find it anywhere and cannot add it back.
I don’t use default_config: so I have updater: in my configuration.yaml. I tried to: remove it –> restart HA –> add again –> restart HA, but binary_sensor.updater entity still won’t appear…
Any ideas?
If you manually deleted it from a file in the .storage folder from outside the UI then my guess is that it should be recreated after a restart.
Another thing to check could be that it is hidden from HA. You can hide sensors that are created by integrations. Perhaps you have ‘hidden’ it and should you revert that.
Indeed I have just hidden this entity… I did not notice that because an option to display hidden entities was moved and I thought it was removed or something.
BTW, it’s a bad change to hide that switch/checkbox in such a place. So intuitive. My example is a good one.
